Old 01-27-2010, 10:45   #1 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
1112 IMEI not Changed
Please see the log and suggest the solution
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 00C629CD:2984DA60
Trying to find patch position ...Ok, found in 12.110 s
Not supported firmware.
Error while processing command !
Can u please also post the supported version of firmware????
Old 01-27-2010, 11:01   #2 (permalink)
.::TR_LAZ::.'s Avatar
Member: 178227
Sonork: 100.1597371
Thanks Meter: 176
UNIVERSAL DESIGN IN BOX credit
GARMENEZOR...tr
Old 01-27-2010, 11:54   #3 (permalink)
adnann5's Avatar
Member: 1158126
Sonork: 100.1589521
Thanks Meter: 475
GARMENEZOR...tr
What do u mean dear????i didn't understand
Old 02-08-2010, 18:07   #4 (permalink)
Member: 178227
Sonork: 100.1597371
Thanks Meter: 176
UNİVERSAL BOX understand YOU
Old 02-08-2010, 18:15   #5 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
Wait MXKEY team work on it
Old 02-08-2010, 18:32   #6 (permalink)
Member: 255072
Thanks Meter: 46
try older firmwares or try mothod 2
Old 04-08-2010, 09:17   #7 (permalink)
Member: 178227
Sonork: 100.1597371
Thanks Meter: 176
MT BOX TIK TIK 5 SECOND.... 5 credis
IMEI not change SL65 ??? EDY.PM DreamBox 1 11-12-2007 10:35
B2000 Imei Not Changed .:Kuku:. Multi-Box 2 01-27-2007 13:43
kg800 imei not change serdar1985 Multi-Box 2 10-12-2006 22:03
Page generated in 0.15652 seconds with 9 queries
