08-27-2010, 16:38 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: just around
Member: 914220 Status: Offline Thanks Meter: 206 | 1112 unlock problem help (ANSWERED) Version: Provider: Mossel (Digicel), Country: Jamaica Counter: 0/3, 0/10 CONFIG_DATA: 3380500000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 33805F BLOCK 2: 1.LOCKED (MCC+MNC): 35805F BLOCK 3: 1.LOCKED (MCC+MNC): 360070 BLOCK 4: 1.LOCKED (MCC+MNC): 352030 BLOCK 5: 1.LOCKED (MCC+MNC): 342750 BLOCK 6: 1.LOCKED (MCC+MNC): 374130 BLOCK 7: 1.LOCKED (MCC+MNC): 363020 BLOCK 8: 1.LOCKED (MCC+MNC): 36269F BLOCK 9: 1.LOCKED (MCC+MNC): 310380 BLOCK 10: 1.LOCKED (MCC+MNC): 34020F BLOCK 11: 1.LOCKED (MCC+MNC): 372020 BLOCK 12: 1.LOCKED (MCC+MNC): 73801F BLOCK 13: 1.LOCKED (MCC+MNC): 70602F BLOCK 14: 1.LOCKED (MCC+MNC): 74603F Updating SIMLOCK ...Error 1 (check this) DCT4PLUS license is not activated, invoking activation ... (check this) Starting License Activation ... SERVER->Served by MXKEY - BLADE Z at host4, agent version 1.1 revision 0.2 Card licenses Updated OK. Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-93_35767301025858_SIM.RPL" Updating SIMLOCK ...ERROR: 01 (check this) Reading Simlock info ... Imei net: 35767301025858 Version: Provider: Mossel (Digicel), Country: Jamaica Counter: 0/3, 0/10 CONFIG_DATA: 3380500000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 33805F BLOCK 2: 1.LOCKED (MCC+MNC): 35805F BLOCK 3: 1.LOCKED (MCC+MNC): 360070BLOCK 4: 1.LOCKED (MCC+MNC): 352030 BLOCK 5: 1.LOCKED (MCC+MNC): 342750 BLOCK 6: 1.LOCKED (MCC+MNC): 374130 BLOCK 7: 1.LOCKED (MCC+MNC): 363020 BLOCK 8: 1.LOCKED (MCC+MNC): 36269F BLOCK 9: 1.LOCKED (MCC+MNC): 310380 BLOCK 10: 1.LOCKED (MCC+MNC): 34020F BLOCK 11: 1.LOCKED (MCC+MNC): 372020 BLOCK 12: 1.LOCKED (MCC+MNC): 73801F BLOCK 13: 1.LOCKED (MCC+MNC): 70602F BL OCK 14: 1.LOCKED (MCC+MNC): 74603F please help me with this modelito |
08-27-2010, 16:59 | #2 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | bro, write manually sim rpl Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-93_35767301025858_SIM.RPL" |
The Following User Says Thank You to net.tarik For This Useful Post: |
02-12-2011, 01:20 | #3 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | hello, i have this kind of problem, and i read somewhere gbluez says to delete eeprom, and unlock again, but now my 1112 becomes simlock corrupted how to repair? already backup full pm, but when i restore it still "simlock corrupted" is 1112 not supported to unlock both direct and patch method? i keep getting simlock update error |
02-12-2011, 01:21 | #4 (permalink) |
02-12-2011, 02:53 | #6 (permalink) | |
Insane Poster Join Date: Feb 2010 Location: philippines
Member: 1225482 Status: Offline Thanks Meter: 45 | Quote:
then unlock | |
02-14-2011, 01:19 | #7 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | already erase eeprom and all flash, already full flash, now simlock is corrupted, before i erase, it is locked.... this is an old model, i don't believe that mxkey cannot handle this ? any advice? because i see many ppl here a experiencing the same problem using mxkey to unlock rh-93 |
02-14-2011, 17:44 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hello, let's do it with hard way: - reset data1 - erase get address, untick safe erase, erase. - reflash, proceed with rpl rebuild by online logger dct4plus imei. - write pm, skip all simlock overwrite. i already write about this some where... BR |
02-17-2011, 15:52 | #10 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | i get this result ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C1F03B:2984DA60 ASIC type: 2 UEM Imei: 35936100596153 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35936100596153.RP L" ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C1F03B:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-93 SW Version: V 5.50 16-06-06 RH-93 (c) NMP Imei plain: ??????????????-? Product Code: 0538686 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MB |
02-23-2011, 14:20 | #12 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | imei is back, but simlock status still corrupted after write pm, skipping simlock write Phone Type: RH-93 SW Version: V 5.50 16-06-06 RH-93 (c) NMP Imei plain: 35936100596153-0 Imei OTP: 00000C60000000 Product Code: 0538686 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MB Language Pack: English,Hindi,Bahasa Indonesia,Filipino Imei net: 35936100596153 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED |
02-23-2011, 15:25 | #13 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | how to repair corrupted simlock, because when i try to init simlock i get this Imei net: 35936100596153 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 Updating SIMLOCK ...Error 1 PhoneType:RH-93 SwVersion: V 5.50 16-06-06 RH-93 (c) NMP MCU file: rh93_05.500 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00C1F03B:2984DA60 Area [01140000-0115FFFF] erased in 0.875 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x16 |
02-28-2011, 16:21 | #14 (permalink) |
Member: 901949 Status: Offline Thanks Meter: 50 | mxkey not a stable working software flash 6500 imei become 12345 even i cannot use this to unlock a cheap phone like 1112 already use free jaf and its working fine please fix this buggy software |
