Old 01-19-2010, 15:35   #1 (permalink)
Member: 701779
Sonork: 100.1622334
Thanks Meter: 121
1200 after imeil logs
here's check logs restart problem
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11685, Date: 15-01-2010
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
 SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 004A0741:DA3BDA66
ASIC type: 11
UEM Imei: 35955401276346
Flash Imei: 35955401276346
MasterCode: 7753440320
RPL saved to "C:\mobileEx\3.3\data\backup\35955401276346_1263915129_BACK.rpl"
Phone Type: RH-99
SW Version: V 3.44 01-09-07 RH-99 (c) NMP
Imei plain: 35955401276346-5
Product Code: 0556729
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: EB
Language Pack:
English,German,Hungarian,Serbian
Imei net: 35955401276346
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data,  No RPL backup will be made for this phone.
1200 after water damage no light mirfanmian Nokia Hardware & Hardware Repair 4 07-27-2011 15:41
1200 dead flashing log posted waqarN70 Nokia Hardware & Hardware Repair 3 04-20-2010 21:42
1200 after unlock contact service nimanima Universalbox 37 01-26-2009 08:19
I have repaired contact service 1200 after ub unlock hridaya Universalbox 10 03-19-2008 09:25
1200 after flash imei ???????????? hamid123 MT-BOX 4 02-19-2008 08:19
Page generated in 0.13654 seconds with 10 queries
