04-30-2009, 22:35 | #1 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303402 Status: Offline Thanks Meter: 346 | 1200 contact service, help me i did flashing, the log Code: Processing file: rh99_05.800 ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST M58MR032] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF u3_st_i.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C231A4:2984DA60 Programming MCU ... rh99_05.800: [DCT4][DCT4 ALGORITHM] (2.26 MB) Supported Ids: 2292 Area [01000000-0100FFFF] erased in 1.141 s Area [01010000-013AFFFF] erased in 1 min 5.484 s Area [013B0000-013EFFFF] erased in 4.578 s Area [017C0000-017EFFFF] erased in 0.047 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 17.906 s File Processed in 1 min 45.093 s Processing file: rh990_nai5.80md ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST M58MR032] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C231A4:2984DA60 Programming Content Pack ... rh990_nai5.80md: [DCT4][DCT4 ALGORITHM] (116.22 KB) Supported Ids: 2292 Area [01380000-013AFFFF] erased in 3.375 s Flash programming ... Programming completed in 0.734 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.109 s File Processed in 16.344 s Processing file: rh99_05.80md ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST M58MR032] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C231A4:2984DA60 Programming PPM ... rh99_05.80md: [DCT4][DCT4 ALGORITHM] (1.19 MB) Supported Ids: 2292 Area [01240000-0124FFFF] erased in 1.219 s Area [01250000-0137FFFF] erased in 21.593 s Flash programming ... Programming completed in 8.859 s File Processed in 38.250 s Flashing completed in 2 min 43.578 s After Flash Processing ... Updating Product Code OK. Reseting Warranty And LifeTimer OK. Reseting Factory Values OK. Uploading PM Writing PMM C:\Program Files\Nokia\Phoenix\Products\rh-99\RH-99_1200.pm Range: 1 - 8 Section: 1, 7 key(s) Section: 2, 1 key(s) Section: 3, 1 key(s) Section: 4, 8 key(s) Section: 5, 1 key(s) Section: 7, 3 key(s) Section: 8, 1 key(s) Completed in 1.250 s PhoneType:RH-99 SwVersion: V 5.80 14-11-08 RH-99 (c) NMP MCU file: rh99_05.800 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPP_v2.x] u3_2nd.fia: [DCT4] version: 4.77.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST M58MR032] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 u3_st_i.fia: [DCT4 ALGORITHM] version: 4.77.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00C231A4:2984DA60 Area [01140000-0115FFFF] erased in 2.219 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 22.985 s Phone Type: RH-99 SW Version: V 5.80 14-11-08 RH-99 (c) NMP Imei plain: 35934602862437-1 Product Code: 0546862 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MD Language Pack: English,Filipino,Vietnamase Total time to process is 3 min 31.531 s the phone still contact service, any solution. |
The Following User Says Thank You to aswancamel For This Useful Post: |
05-01-2009, 14:43 | #2 (permalink) |
Freak Poster Join Date: Dec 2006 Location: indonesia
Member: 412834 Status: Offline Thanks Meter: 215 | updating simlock it's ok and still contac service, maybe u have hardware problem chek bsi line first, sometime this model have problem on cpu ic...... br. |
The Following User Says Thank You to gsm_enggine For This Useful Post: |
Nokia 1200 Contact Service ... help | alkesh02 | Nokia Hardware & Hardware Repair | 34 | 03-16-2011 21:18 |
1200 contact service help!!! | orao | Nokia Digital Core Technology 4 ( DCT-4 ) | 9 | 12-19-2008 07:56 |
3300 contact service help me | kaijae2004 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-25-2007 16:29 |
6125 contact service help me | saiedham | Nokia Hardware & Hardware Repair | 3 | 04-19-2007 15:28 |
3350 contact service .....help me,.... | alf007 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 02-03-2002 16:51 |
