Old 10-07-2010, 10:09   #1 (permalink)
Registered User
Member: 1322132
Thanks Meter: 8
1202 ????????????3 what solution [SOLVED]
Performing Flash Authentication ...OK
UEM ID: 00A44285A3BDA66
Programming FLASH Imei ...failed
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei
(OTP) ...
UEM programmed successfully.
Phone Type: RH-112
SW Version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: 35520203549114-4
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: IL
Language Pack:
- not available.
Imei net: 35520203549114
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
Old 10-07-2010, 10:10   #2 (permalink)
Registered User
Member: 1322132
Thanks Meter: 8
decuse me plez.................................
gsm stars........................................
Old 10-07-2010, 10:38   #3 (permalink)
Deepesh Sharma's Avatar
Member: 1301233
Sonork: Closed
Thanks Meter: 9,297
full erase your phone bro. and flash with latest version & write good pm then unlock and you will solv your problem i have done many times its work 100%
The Following 2 Users Say Thank You to Deepesh Sharma For This Useful Post:
Old 10-07-2010, 10:40   #4 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
just unlock it and all will b fine
The Following 2 Users Say Thank You to klmamn For This Useful Post:
Old 10-07-2010, 12:39   #5 (permalink)
Registered User
Member: 1322132
Thanks Meter: 8
now this info
Phone Type: RH-112
Ppm Id: IL
Language Pack:
- not available.
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
(Invalid UEM Data, No RPL backup will be made for this phone.)
Old 10-07-2010, 12:56   #6 (permalink)
Registered User
Member: 1322132
Thanks Meter: 8
I RITE FULL PM THEN UPDATE SP LOCK PROBLUME
1000000000% OK ..................................
TANKX NICE COMPNY TO .............BR, s
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
SIM restriction pending -- what does it mean? Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-17-2011 10:05
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE £40 (1+) -- £30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Page generated in 0.17600 seconds with 9 queries
