02-25-2010, 11:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | ..:1202:.. again dead set recover by mx-key sing device: J.A.F, FW ver: 01.B2 Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rh112_004.030 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004A08AC:2984DA60 Area [01000000-0100FFFF] erased in 1.234 s Area [01010000-013AFFFF] erased in 1 min 12.047 s Area [013B0000-013EFFFF] erased in 4.969 s Area [017C0000-017EFFFF] erased in 0.062 s Area [01FC0000-01FEFFFF] erased in 0.063 s Flash programming ... Programming completed in 16.610 s File Processed in 1 min 46.688 s Processing file: rh1120_nai04.03aa as CNT [DCT4,DCT4 ALGORITHM] size: 132.86 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004A08AC:2984DA60 Area [01380000-013AFFFF] erased in 3.719 s Flash programming ... Programming completed in 0.968 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.172 s File Processed in 26.297 s Processing file: rh112_004.03aa as PPM [DCT4,DCT4 ALGORITHM] size: 1.05 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 004A08AC:2984DA60 Area [01240000-0124FFFF] erased in 1.281 s Area [01250000-0137FFFF] erased in 23.875 s Flash programming ... Programming completed in 7.609 s File Processed in 44.422 s Flashing completed in 2 min 57.625 s Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35826503431840-9 Product Code: 0590461 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AA Language Pack: - not available. Imei net: 35826503431840 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 26.282 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 13.609 s great work |
nokia x3 dead after flash by mx-key (answered) | bilalgsm2010 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 10-30-2010 02:44 |
.....:1202 dead:.... Successfully recover by mx-key. Log here------ | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 02-15-2010 05:51 |
how to write bb5 imei in bb5 sets by mx key | cheeni | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 21:11 |
WAW Great news again by mx-key Super dongle repair free | Maiwand khan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 02-03-2010 13:16 |
Nokia 1661-2 RH-122 dead recovered by mx-key:)- | sahil2000ind | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 12-21-2009 09:36 |
