05-31-2010, 21:30 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | 1202 contact service |
06-01-2010, 08:08 | #6 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | log are here Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0060248EA3BDA66 ASIC type: 11 UEM Imei: 35826403249958 Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35826403249958-4 Product Code: 0562205 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: ID Language Pack: - not available. TimeStamp: 2008-11-17T07:47:44Z SW Version: 03.00 Variant Version: 001 ProductProfile: RH112_0562205_03.00_001.spr Simlock: 0562205_SimLockDataVerifier_vDCT4.sim Imei net: 35826403249958 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Invalid UEM Data, No RPL backup will be made for this phone. |
06-01-2010, 09:28 | #11 (permalink) |
Banned Join Date: Nov 2009 Location: @ work Age: 16
Member: 1169642 Status: Offline Sonork: 1587581 Thanks Meter: 234 | brother check lcd if not do like this http://forum.gsmhosting.com/vbb/f139...af-ufs-896045/ |
06-01-2010, 10:37 | #12 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Invalid UEM Data, No RPL backup will be made for this phone | |
06-02-2010, 11:12 | #14 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0060248EA3BDA66 ASIC type: 11 UEM Imei: 35826403249958 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35826403249958.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0060248EA3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed What is this??? Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35826403249958-4 Product Code: 0562271 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35826403249958 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Need more help plz........... |
06-02-2010, 11:32 | #15 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed |
The Following User Says Thank You to MOURAD™ For This Useful Post: |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
