.....:1202 dead:.... Successfully recover by mx-key. Log here------ SET WAS FULLY DEAD.NO POWER. I RECOVER IT BY FLASHING WITH MX-KEY. LOG HERE------- Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Processing file: rh112_004.030 as MCU [DCT4,DCT4 ALGORITHM] size: 2.29 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0018DA24:2984DA60 Area [01000000-0100FFFF] erased in 1.344 s Area [01010000-013AFFFF] erased in 1 min 12.266 s Area [013B0000-013EFFFF] erased in 5.062 s Area [017C0000-017EFFFF] erased in 0.063 s Area [01FC0000-01FEFFFF] erased in 0.047 s Flash programming ... Programming completed in 16.562 s File Processed in 1 min 48.187 s Processing file: rh1120_nai04.03aa as CNT [DCT4,DCT4 ALGORITHM] size: 132.86 KB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0018DA24:2984DA60 Area [01380000-013AFFFF] erased in 3.719 s Flash programming ... Programming completed in 0.968 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.078 s File Processed in 24.312 s Processing file: rh112_004.03aa as PPM [DCT4,DCT4 ALGORITHM] size: 1.05 MB Supported Ids: 2293 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0018DA24:2984DA60 Area [01240000-0124FFFF] erased in 1.250 s Area [01250000-0137FFFF] erased in 23.594 s Flash programming ... Programming completed in 7.594 s File Processed in 44.157 s Flashing completed in 2 min 56.922 s Phone Type: RH-112 SW Version: V 04.03 29-06-09 RH-112 (c) Nokia Imei plain: 35319603065685-3 Product Code: 0564054 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: AA Language Pack: - not available. Imei net: 35319603065685 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 19.000 s |
thanxs for test report keep it up................. |
which cable did you use |
the best cables in market GPG or IPMART |
i mean fbus or easy |
Whats new bro...... ???????? already done many time ago http://forum.gsmhosting.com/vbb/show...&postcount=483 |
i cant beleve this is not possible bcoz not supoort any prodect this mode even mx key say evrey time this model not supported r u say i flashed bro dont fun |
just unlock not supported but you can flash again & again no problum done many times |
Imei net: 35799103759482 Version: SIMLOCK SERVER Provider: Tesco Mobile (3510i), Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2340000300000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 23410F 2.LOCKED (GID1): 0AFF PhoneType:RH-105 SwVersion: V 5.23 10-03-08 RH-105 (c) NMP MCU file: rh105_05.230 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001FC0FB:2984DA60 Area [01000000-0101FFFF] erased in 0.797 s Area [01140000-0115FFFF] erased in 0.797 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 23.375 s Reading Simlock info ... Imei net: 35799103759482 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
bro, if you see my log carefully than you understand. yes i flash this set by easy cable.and it is done100% |
