Old 02-10-2010, 11:48   #1 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 875
.....:1202 dead:.... Successfully recover by mx-key. Log here------
SET WAS FULLY DEAD.NO POWER. I RECOVER IT BY FLASHING WITH MX-KEY.
LOG HERE-------
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Processing file: rh112_004.030 as MCU
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 0018DA24:2984DA60
Area [01000000-0100FFFF] erased in 1.344 s
Area [01010000-013AFFFF] erased in 1 min 12.266 s
Area [013B0000-013EFFFF] erased in 5.062 s
Area [017C0000-017EFFFF] erased in 0.063 s
Area [01FC0000-01FEFFFF] erased in 0.047 s
Flash programming ...
Programming completed in 16.562 s
File Processed in 1 min 48.187 s
Processing file: rh1120_nai04.03aa as CNT
[DCT4,DCT4 ALGORITHM] size: 132.86 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.719 s
Programming completed in 0.968 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.078 s
File Processed in 24.312 s
Processing file: rh112_004.03aa as PPM
[DCT4,DCT4 ALGORITHM] size: 1.05 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.250 s
Area [01250000-0137FFFF] erased in 23.594 s
Programming completed in 7.594 s
File Processed in 44.157 s
Flashing completed in 2 min 56.922 s
Phone Type: RH-112
SW Version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35319603065685-3
Product Code: 0564054
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: AA
Language Pack:
- not available.
Imei net: 35319603065685
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 3 min 19.000 s
The Following User Says Thank You to shahinahmed007 For This Useful Post:
Old 02-10-2010, 11:54   #2 (permalink)
rajesh_ch's Avatar
Member: 618404
Sonork: 100.1624568
Thanks Meter: 284
thanxs for test report keep it up.................
Old 02-10-2010, 12:10   #3 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 633
which cable did you use
Old 02-10-2010, 12:20   #4 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
the best cables in market GPG or IPMART
Old 02-10-2010, 13:07   #5 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 633
i mean
fbus or easy
Old 02-10-2010, 13:47   #6 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 875
easy cable------------------
Old 02-10-2010, 14:36   #7 (permalink)
Member: 770503
Thanks Meter: 986
Whats new bro...... ???????? already done many time ago
MXBOX - Successfully Unlocked/repaired/flashed Phones By MXBOX
Old 02-10-2010, 15:09   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 686
i cant beleve this is not possible bcoz not supoort any prodect this mode even mx key say evrey time this model not supported r u say i flashed bro dont fun
Old 02-10-2010, 16:38   #9 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
just unlock not supported but you can flash again & again no problum done many times
Old 02-15-2010, 00:36   #10 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 752
Imei net: 35799103759482
Provider: Tesco Mobile (3510i), Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2340000300000000
PROFILE_BITS: 8000000000010002
BLOCK 1: 1.LOCKED (MCC+MNC): 23410F 2.LOCKED (GID1): 0AFF
PhoneType:RH-105
SwVersion: V 5.23 10-03-08 RH-105 (c) NMP
MCU file: rh105_05.230
Trying to find patch position ...OK, case id: 3
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
UEM ID: 001FC0FB:2984DA60
Area [01000000-0101FFFF] erased in 0.797 s
Area [01140000-0115FFFF] erased in 0.797 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 23.375 s
Reading Simlock info ...
Counter: 0/3, 0/10
PROFILE_BITS: 800000000001000B
Old 02-15-2010, 05:51   #11 (permalink)
Member: 672312
Sonork: 100.1589313
Thanks Meter: 875
bro,
if you see my log carefully than you understand.
yes i flash this set by easy cable.and it is done100%
Nokia E71x rm-462 Successfully Unlocked By MX Key. sanjoychy MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 03-16-2010 16:42
..:1202:.. again dead set recover by mx-key shahinahmed007 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-25-2010 11:53
E71 successfully unlock by MX KEY faizan_gsm MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-13-2010 10:29
n82 successfully unlock by MX-Key marvin03 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 09-28-2009 09:40
6210n rm 408 successfully unlocked by mx key ..:::YMG:::.. Nokia Base Band 5 ( BB-5 ) 0 09-21-2009 05:06
Page generated in 0.36339 seconds with 8 queries
