Old 06-30-2010, 04:41   #1 (permalink)
Member: 578236
Thanks Meter: 31
1202-Failed to read SP data
Hi all friends and mxkey teams
Phone dropped in water, already cleaned
I flash the latest version and update sp lock, Stile the same
then
Erase Flash
write full flash
write PM from good phone
init simlock, update sp lock
problem still the same
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00F01839:2984DA60
Area [01380000-013AFFFF] erased in 3.750 s
Flash programming ...
Programming completed in 1.156 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.032 s
File Processed in 23.875 s
Processing file: rh112_004.03en as PPM
[DCT4,DCT4 ALGORITHM] size: 1.22 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.281 s
Area [01250000-0137FFFF] erased in 23.594 s
Programming completed in 9.813 s
File Processed in 45.578 s
Flashing completed in 2 min 57.969 s
Phone Type: RH-112
SW Version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: ??????????????-?
Product Code: 0562271
Cellular System: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: EN
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000030000
SIMLOCK_DATA corrupted!
Total time to process is 3 min 3.797 s
and i test to rebuild Imei , it show like this
UEM ID: 00F01839A3BDA66
ASIC type: 11
UEM Imei: 35832203283271
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35832203283271.RP L"
Programming FLASH Imei ...failed
warning: For UEM write, VBAT needs to be atleast: 5.2V
Programming UEM Imei (OTP) ...
UEM programmed successfully.
Phone Type: RH-112
Imei plain: 35832203283271-5
Ppm Id: EN
Language Pack:
- not available.
what's wrong with this phone
How to use battery 5.2v
is it the UEM demage?
is it Imei problem?
is it SP Lock problem, how to solve it?
is it because of the Mxkey not activate?
Kindly give some idea with this error, I met many phones
thanks in advance
Old 06-30-2010, 04:56   #2 (permalink)
ABDULMANAN's Avatar
Member: 754324
Sonork: LOVE MOHAMMAD (S.A.W)
Thanks Meter: 476
unlock it if u not activated then u have 50 free credit and have many other free unlock tools
Old 06-30-2010, 05:01   #3 (permalink)
Member: 578236
Thanks Meter: 31
the free credits it should be ok, because so far i never use it from the first time of free credit 1000 then 50/50
thanks
Old 06-30-2010, 08:26   #4 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 388
Simple use MT BOX if MX-KEY can't help
Old 06-30-2010, 08:30   #5 (permalink)
BAHRI PhoneWala's Avatar
Member: 959013
Thanks Meter: 262
not help with mt i already tried
b.r
bahri phonewala
Old 06-30-2010, 12:51   #6 (permalink)
Member: 578236
Thanks Meter: 31
very sorry , I don't have MT
but to day have 3 phone have this probem
Only one phone can be work 100%
the log like this
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
UEM ID: 00CC0217A3BDA66
ASIC type: 11
UEM Imei: 35823003138411
Flash Imei: 35823003138411
MasterCode: 4656247451
RPL saved to "C:\mobileEx\3.4\data\backup\35823003138411_BACK.r pl"
Phone Type: RH-112
SW Version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: 35823003138411-9
Product Code: 0563390
ASIC ID: 0x2293, type: 0
Ppm Id: AG
Language Pack:
- not available.
and the phone not any erase
Just write the latest version 3 time , problem stile the same
then I just change the LCD , the problem gone away
Now work 100%
So this is not a good or right solution
Just only done by luck , maybe some thing sort at the LCD
another 2 phone stile waiting for the right solution
thanks
Old 06-30-2010, 12:57   #7 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 310
Imei net: 35319203910598
Provider: Orange, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343300000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.LOCKED (MCC+MNC): 23433F
BLOCK 2: 1.LOCKED (MCC+MNC): 23486F
DCT4PLUS license is not activated, invoking activation ...
Starting License Activation ...
Socket error (11001): Host not found
Calculating SIMLOCK RPL using security server ...
Old 06-30-2010, 13:28   #8 (permalink)
Member: 578236
Thanks Meter: 31
then
Erase Flash
write full flash
Supported Ids: 2293
Supported Ids: 2293
Phone Type: RH-112
Ppm Id: EN
Language Pack:
- not available.
Counter: 0/3, 0/10
ASIC type: 11
Phone Type: RH-112
Ppm Id: EN
Language Pack:
- not available.
is it Imei problem?
thanks in advance
OK my first phone now done
I reball all CPU, UEM, Flash IC
after that I check bus again , stile
Then do Update SP lock 1 time Done
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC type: 11
Flash Imei: 35832203283271
MasterCode: 1704632134
RPL saved to "C:\mobileEx\3.4\data\backup\35832203283271_BACK.r pl"
Phone Type: RH-112
Ppm Id: EN
Language Pack:
- not available.
Imei net: 35832203283271
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
info
Version Info:
MCU SW version: V 04.03 29-06-09 RH-112 (c) Nokia
HW version: 1000
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: UNKWN: IDs: 00:ff:00
PPM version: V 04.03 29-06-09 RH-112 (c) Nokia EN
ADSP SW version: p V 04.03\n29-06-09\nRH-112\n(c) NMP\nen
Product Info:
Production serial number: HBC532911
Product code: 0562271
Module code: 0203762
Basic production code: 0558505
Serial Numbers:
IMEI plain: 358322032832715
IMEI spare to net: 3A 85 23 02 23 38 72 01
IMEI SV to net: 33 85 23 02 23 38 72 11 F9
Other Info:
CS type : GSM/DCS1800
BSI: 4.4 KOhm
Counter: 0/3, 0/10
Thank alot to all friend and Mxkey teams
The Following User Says Thank You to Liheng For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 11 06-26-1999 06:22
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.48977 seconds with 8 queries
