Old 07-24-2010, 09:45   #1 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
1202 incoming call busy?
1202 out going call ok but incoming calls respond busy.....
after doing bus check everything is ok but at last shows this msg and also dont save imei.....
Invalid UEM Data, No RPL backup will be made for this phone.
already done everything that i can with mx key but problem is the same now where is fault plz need urgent reply...........
Old 07-24-2010, 09:51   #2 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
please POST phone information log
Old 07-24-2010, 12:25   #3 (permalink)
decentevil's Avatar
Member: 691960
Sonork: 100.1592294
Thanks Meter: 145
set logs r tatally ok same as an ok phone but at last when it saves rpl it shows this msg ............................... and 1 other issue phone also restarts after some time.......
Old 07-24-2010, 12:35   #4 (permalink)
ARS.Rehman's Avatar
Member: 491455
Sonork: On My LAB
Thanks Meter: 296
power on ur mobile with simcard dail ##002# and press ok
The Following User Says Thank You to ARS.Rehman For This Useful Post:
Old 07-24-2010, 12:39   #5 (permalink)
rafi_5217705's Avatar
Member: 627475
Sonork: 100.1594828
Thanks Meter: 1,144
yes i agree with m,r ARS
and then pres ##21# maybe your problem is solve
Unlocked network on 5110v5.28 does not make calls, but other network does? Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-01-2001 16:43
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
Nokia 6110 without net. couldnīt call 911 either! DennisT Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-09-2000 11:37
Page generated in 0.14215 seconds with 9 queries
