02-05-2011, 12:03 | #6 (permalink) |
Registered User Join Date: Dec 2006 Location: d i khan
Member: 410659 Status: Offline Thanks Meter: 18 | ng MCU ID MCU ID: 0x2293 FLASH ID0: 260600EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 02.80 26-09-08 RH-112 (c) NMP HW version: 2006 PCI version: UEM version: 1328 UPP version: 8851 RFIC version: 0700 DSP version: ICPR81_08w31_UPP LCD version: WIN:SERI:90 NT7542 PPM version: V 02.80 26-09-08 RH-112 (c) NMP IA ADSP SW version: V 02.80\n26-09-08\nRH-112\n(c) NMP\naa_demo Production serial number: 1633B1AAI Product code: 0569747 Module code: 0204403 Basic production code: 0574232 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 352695048140447 IMEI spare to net: 3A 25 96 05 84 41 40 04 IMEI SV to net: 33 25 96 05 84 41 40 14 F1 Master Code: 1423755656 Phone type: RH-112, Software version: 02.80, Language Pack: IA User code: ÿ# Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0569747 Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-112\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
02-05-2011, 12:04 | #7 (permalink) |
Banned Join Date: Apr 2008
Member: 762819 Status: Offline Thanks Meter: 232 | No dears. don't give someone the wrong solution. The real solution is: 1. Send ur phone to any other country. will work fine. 2. U can't change its IMEI, U need to change its. UEM and then write RPL, then it will work fine. I've tested my sets with this problem . . . |
02-05-2011, 12:08 | #8 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: \/\/ 0RLD \/\/ IDE
Member: 238374 Status: Offline Sonork: 100.1597005 Thanks Meter: 1,087 | Quote:
here is details and ur problem 352695048140447 IMEI is reported stolen! | |
5110 - Incerte simcard | Moc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 10-08-2001 00:07 |
5130v3.xx won't accept any simcard | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-06-2001 13:15 |
SimCard Blocked | Allen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-20-2000 04:25 |
5110 5.28 simcard rejected | koloksky | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-03-2000 13:44 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
