Old 04-14-2010, 13:07   #1 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
1202 unlock done but still in contact dervise
Imei net: 35319603062351
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Calculating SIMLOCK RPL using security server ...OK
RPL saved to "C:\mobileEx\3.3\data\backup\RH-112_35319603062351_SIM.RPL"
Updating SIMLOCK ...OK
Reading Simlock info ...
Counter: 0/3, 0/10
PROFILE_BITS: 000000000003000B
The Following User Says Thank You to Master Software For This Useful Post:
Old 04-14-2010, 13:20   #2 (permalink)
Member: 380077
Sonork: 100.1601214
Thanks Meter: 55
erase the phone
flash
write good pm
then unlock it again
it should with method
Old 04-14-2010, 13:54   #3 (permalink)
Member: 1149013
Thanks Meter: 247
........................Manole.................... ..???
Old 04-14-2010, 14:03   #4 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
whats status before unlock.?
Old 04-14-2010, 14:07   #5 (permalink)
kasrawiz's Avatar
Member: 340564
Sonork: 1591034
Thanks Meter: 529
flash it with newest files it will be done
Old 04-15-2010, 01:02   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
do rewrite PM file the unlock
if not help
reassembly phone hardware
br,
Old 04-15-2010, 01:30   #7 (permalink)
Sniper_04's Avatar
Member: 704097
Sonork: 100.1607742
Thanks Meter: 820
What the status of unit before you unlock?...
try to check lcd....
Full erase and fullflash your phone and write good pm
Old 04-15-2010, 01:35   #8 (permalink)
Member: 433141
Thanks Meter: 4
write good pm.
Old 04-15-2010, 04:51   #9 (permalink)
Crazy Poster
Member: 1036237
Thanks Meter: 8
if not help
br,
I AGREE....!! the same om andra
SELFTEST MX checks using keys or HWK.
after that, upload it here log.
Old 04-15-2010, 05:11   #10 (permalink)
Member: 690327
Thanks Meter: 17
Use SELTEST to Analyse....Then Post it here...
br
Old 04-15-2010, 06:46   #11 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
wts before condition dear...post
Old 04-15-2010, 06:53   #12 (permalink)
Member: 547967
Thanks Meter: 653
Hello
bro it is related to hardware check inside phone.
Thanxs
Old 04-15-2010, 06:56   #13 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Counter: 0/3, 0/10
Counter: 0/3, 0/10
First remove local mode resistor.If not solved than change the display.
Old 04-15-2010, 07:13   #14 (permalink)
GSMunlockvilla's Avatar
Member: 1022742
Thanks Meter: 187
if ur problem still same then should be hardware normaly cases is display
Regards
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
Page generated in 0.25779 seconds with 9 queries
