02-04-2010, 10:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2007
Member: 582669 Status: Offline Sonork: 100.1592908 Thanks Meter: 69 | 1208 contact service Library version: 1.0.0.11985, Date: 03-02-2010 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008E3A9AA3BDA66 ASIC type: 11 UEM Imei: 35809701749642 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35809701749642_BA CK.rpl" Processing file: rh105_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008E3A9A:2984DA60 Area [01000000-0100FFFF] erased in 1.047 s Area [01010000-013AFFFF] erased in 1 min 1.609 s Area [013B0000-013EFFFF] erased in 4.360 s Area [017C0000-017EFFFF] erased in 0.016 s Area [01FC0000-01FEFFFF] erased in 0.032 s Flash programming ... Programming completed in 15.594 s File Processed in 1 min 34.297 s Processing file: rh1050_nai5.80ua as CNT [DCT4,DCT4 ALGORITHM] size: 139.88 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008E3A9A:2984DA60 Area [01380000-013AFFFF] erased in 3.234 s Flash programming ... Programming completed in 0.969 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.046 s File Processed in 23.672 s Processing file: rh105_05.80ua as PPM [DCT4,DCT4 ALGORITHM] size: 1.20 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 008E3A9A:2984DA60 Area [01240000-0124FFFF] erased in 1.062 s Area [01250000-0137FFFF] erased in 20.141 s Flash programming ... Programming completed in 8.453 s File Processed in 41.234 s Flashing completed in 3 min 12.953 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RH-105 SW Version: V 5.80 14-11-08 RH-105 (c) NMP Imei plain: 35809701749642-7 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: UA Language Pack: - not available. Imei net: 35809***** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Total time to process is 3 min 20.656 s |
02-04-2010, 10:59 | #3 (permalink) |
Freak Poster Join Date: Oct 2008 Location: mumbai
Member: 875607 Status: Offline Sonork: [email protected] Thanks Meter: 10 | brother write good pm ur problem ll b solved or flash it in mxkey ur problem ll be 100% solved |
1200,1208,1208 Contact servic solution.Tested by me With JAF/UFS. | Dooha_Bd | Nokia Digital Core Technology 4 ( DCT-4 ) | 15 | 03-21-2013 04:36 |
help: nokia 1208 contact service | bamogil | Universalbox | 55 | 11-26-2009 08:19 |
1208 contact service.1208 after flashing show's as contact service................. | dhineshh | Nokia Hardware & Hardware Repair | 7 | 10-05-2009 17:09 |
1208 contact service 1208 | mony_tornado200 | Nokia Hardware & Hardware Repair | 4 | 08-15-2008 20:34 |
