Old 06-27-2010, 15:00   #1 (permalink)
Member: 1015645
Thanks Meter: 113
1208 show local mode but not on here is logs mxkey
i have got 1208 set flashing during cnt file not writing here is logs of mxkey what's problem plz help me
Old 06-27-2010, 15:03   #2 (permalink)
Member: 199814
Thanks Meter: 1,936
try to flash using easy cable..
Old 06-27-2010, 15:07   #3 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
@zeedan
Check in hardware, many times water damage.
Br.
Shashank
Old 06-27-2010, 15:07   #4 (permalink)
Member: 1015645
Thanks Meter: 113
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...OK
UEM ID: 00582DEDA3BDA66
ASIC type: 11
UEM Imei: Empty
Old 06-27-2010, 17:09   #5 (permalink)
curvenger's Avatar
Member: 1014781
Thanks Meter: 177
ASIC type: 11
UEM Imei: Empty
Not good, UEM IMEI is empty, you need to write it back, usually UEM is OTP(one time programable) and maybe you will not be able to write imei to it, if this is the case you need to replace UEM and then write the IMEI, But first try to full flash it and maybe the Imei will appear again, If you cannot flash it, then post the flash error log here.
Old 06-27-2010, 18:51   #6 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
agree with you this time
Old 06-28-2010, 07:15   #7 (permalink)
Member: 640856
Thanks Meter: 15
full flash with any version> write pm> unlock > ur problem solved....................
goodluck..........
Old 06-28-2010, 07:21   #8 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 74
Hardware problem. use search button
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 18 12-23-2014 08:03
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.30019 seconds with 8 queries
