12-16-2009, 13:29 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Gojra
Member: 279362 Status: Offline Sonork: 100.1594141 Thanks Meter: 500 | 1208 simlock_data corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11446, Date: 25-11-2009 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0050E6C0A3BDA66 ASIC type: 11 UEM Imei: 35351602086362 Flash Imei: 35351602086362 MasterCode: 0430453407 Flash Imei: 35351602086362 RPL saved to "C:\mobileEx\3.3\data\backup\RPL\35351602086362_BA CK.rpl" Processing file: rh105_05.910 as MCU [DCT4,DCT4 ALGORITHM] size: 2.28 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0050E6C0:2984DA60 Area [01000000-0100FFFF] erased in 0.406 s Area [01010000-013AFFFF] erased in 22.625 s Area [013B0000-013EFFFF] erased in 1.609 s Area [017C0000-017EFFFF] erased in 0.031 s Area [01FC0000-01FEFFFF] erased in 0.032 s Flash programming ... Programming completed in 14.500 s File Processed in 55.219 s Processing file: rh1050_nai5.91ia as CNT [DCT4,DCT4 ALGORITHM] size: 141.12 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0050E6C0:2984DA60 Area [01380000-013AFFFF] erased in 1.218 s Flash programming ... Programming completed in 0.906 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.031 s File Processed in 25.687 s Processing file: rh105_05.91ia as PPM [DCT4,DCT4 ALGORITHM] size: 1.19 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0050E6C0:2984DA60 Area [01240000-0124FFFF] erased in 0.422 s Area [01250000-0137FFFF] erased in 7.594 s Flash programming ... Programming completed in 7.656 s File Processed in 44.641 s Flashing completed in 3 min 5.047 s Phone Type: RH-105 SW Version: V 5.91 27-03-09 RH-105 (c) NMP Imei plain: 35351602086362-5 Product Code: 0549920 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. Imei net: 35351602086362 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! Total time to process is 3 min 12.032 s |
1208 SIMLOCK_DATA corrupted! | Dudiso | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-08-2010 18:51 |
SIMLOCK_DATA corrupted! | R@ZIB-BD | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 07-30-2009 21:43 |
N85 SIMLOCK_DATA corrupted | godlfc | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 07-26-2009 09:45 |
6681 SIMLOCK_DATA corrupted!?? | mdmosheur | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 07-05-2009 07:25 |
n95 SIMLOCK_DATA corrupted!?? | SAN INFOTECH | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 07-03-2009 05:51 |
