03-26-2010, 01:17 | #1 (permalink) |
Freak Poster Join Date: May 2007
Member: 515830 Status: Offline Thanks Meter: 80 | 1208b boot error after update please help thnks Using device: POTATO BOX, FW ver: 01.B0 Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010) Boot error: 55 04 00 92 - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Processing file: rh106_05.320 as MCU [DCT4,DCT4 ALGORITHM] size: 2.07 MB Supported Ids: 2292 Boot error: 55 04 00 FF - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. flashing terminated ! Flashing terminated with error(s) in 36.438 s Phone Type: RH-106 SW Version: V 5.32 05-18-08 RH-106 (c) NMP Imei plain: xxxxxxxxxxxxxx Product Code: 0564129 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: UB Language Pack: - not available. Imei net: xxxxxxxxxxxxx Version: SIMLOCK SERVER Provider: CTI Movil, Country: Argentina Counter: 0/3, 0/10 CONFIG_DATA: 7223100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.LOCKED (MCC+MNC): 722310 BLOCK 2: 1.LOCKED (MCC+MNC): 74810F BLOCK 3: 1.LOCKED (MCC+MNC): 74402F |
firmware 2.25. error after update! | Mobile | Smart-Clip | 1 | 05-19-2006 10:38 |
error after update | g-zona | Griffin | 11 | 09-14-2004 07:26 |
