07-03-2010, 09:20 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 1209 erasing error Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001831B3A3BDA66 ASIC type: 11 UEM Imei: 35933302537578 Flash Imei: 35933302537578 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35933302537578_BA CK.rpl" Processing file: rh105_05.800 as MCU [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001831B3:2984DA60 Area [01000000-0100FFFF] erased in 0.531 s Area [01010000-013AFFFF] erasing ... Error while erasing 0x01270000-0x0128FFFF, Result: 01000000 flashing terminated ! Flashing terminated with error(s) in 1 min 13.031 s RX Buffer: 0100000000B172 wat must the problem here, plz help me bros |
07-03-2010, 10:53 | #7 (permalink) |
Member: 282510 Status: Offline Thanks Meter: 33 | there is nothing to post log since mx key cnt detect the phone, any way here is bus check log: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
Avoid 3 times error code in Nokia 6185 | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-08-2000 20:24 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
