Old 11-24-2010, 08:46   #1 (permalink)
ZubairArain's Avatar
Member: 751908
Thanks Meter: 186
1280 not powered on...
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU ID: A200341100 [X-GOLD 110]
Sending Primary Boot Loader ...OK
Changing baudrate to: 921600
Sending Secondary Boot Loader ...OK
BootloaderString: SE0_091125 F11
Boot mode: CC
EBL version: 10.13, Default_RAM_Bootloader
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing CODE:hw_b2_rm647_r03.600.fls from file rm647_003.600
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming ...
Programming completed in 45.031 s
Erasing area 0x00C60000-0x00EAFFFE ...OK
Programming ...
Programming completed in 49.485 s
Erasing area 0x00FFC000-0x00FFFFFE ...OK
Programming ...
Programming completed in 0.047 s
Checksum failed
Processing CUST:hw_b2_rm647_003.60ij.fls from file rm647_003.60ij
Erasing area 0x00210000-0x0045FFFE ...OK
Programming ...
Programming completed in 22.609 s
Checksum failed
Processing CUST:hw_b2_rm6470_nai03.60ij.fls from file rm6470_nai03.60ij
Erasing area 0x00EB0000-0x00F7FFFE ...OK
Programming ...
Programming completed in 6.390 s
Checksum failed
Flashing completed in 3 min 54.406 s
Phone Type: RM-647
SW Version: V 03.60 01-04-10 RM-647 (c) Nokia
Imei plain: 35152404141558-3
Product Code: 0592303
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IJ
Language Pack:
- not available.
Imei net: 35152404141558
Version:
Provider: GSM Test Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Old 11-24-2010, 08:59   #2 (permalink)
Member: 392149
Thanks Meter: 199
Bro many time face this problem make self test and post here
always flashing complte but not power on make self test you
can see there LCD falied
BR,
Old 11-24-2010, 09:10   #3 (permalink)
Member: 751908
Thanks Meter: 186
Phone Type: RM-647
SW version: V 03.60 01-04-10 RM-647 (c) Nokia
ID Test name Startup Result
42 RADIO Y passed
39 WARRANTY Y passed
33 SIM_LOCK Y passed
10 PPM_VALIDITY Y passed
43 LCD Y !failed !
80 KEY Y passed
81 PA Y passed
82 ADC1 Y passed
83 RTC_32KHZ Y passed
84 GPIO_LIGHT Y passed
85 HOOK_KEY Y passed
86 ACCESSORY Y passed
87 SIM_IF Y passed
88 SIM_INSERTED Y !no signal
90 FLASHCHK Y passed
91 SECURITY Y passed
Old 11-24-2010, 09:11   #4 (permalink)
Member: 751908
Thanks Meter: 186
BR,
do u mean change the lcd ???
The Following User Says Thank You to ZubairArain For This Useful Post:
Old 11-24-2010, 09:15   #5 (permalink)
sajidshah50's Avatar
Member: 1016490
Thanks Meter: 290
br check ur lcd ways....may b some points supply break from anywhere.....if everything is ok then change lcd
The Following User Says Thank You to sajidshah50 For This Useful Post:
Old 11-25-2010, 08:05   #6 (permalink)
Member: 392149
Thanks Meter: 199
Yes bro change or resold LCD it ll be ok
BR,
Old 01-20-2011, 15:01   #7 (permalink)
Member: 383823
Thanks Meter: 28
yes brother change lcd, for me worked good
thanks
Old 02-18-2011, 11:56   #8 (permalink)
Vichka Kham's Avatar
Member: 959779
Sonork: 100.1604117
Thanks Meter: 80
1280 flashing ok and seftest ok
Passed ST_RADIO_TEST
Passed ST_WARRANTY_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_PPM_VALIDITY_TEST
Passed ST_LCD_TEST
Passed ST_KEY
Passed ST_PA
Failed ST_ADC1
Passed ST_RTC_32KHZ
Passed ST_GPIO_LIGHT
Passed ST_HOOK_KEY
Failed ST_ACCESSORY
Passed ST_SIM_IF
Failed ST_SIM_INSERTED
Passed ST_FLASHCHK
Passed ST_SECURITY
but not power on
Old 02-19-2011, 13:27   #9 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
yes bro try to change lcd or check the line in lcd...
Old 02-20-2011, 03:41   #10 (permalink)
Member: 959779
Sonork: 100.1604117
Thanks Meter: 80
still not power on help other solution brother
Old 10-26-2011, 17:15   #11 (permalink)
Member: 149247
Thanks Meter: 14
i have seme broblem
any one help me
Old 09-29-2012, 06:57   #12 (permalink)
Member: 883248
Sonork: 31111
Thanks Meter: 7
i have solved same problem st-ADC1 Y is failed
and i solved this problem by rehote processor only and solved the problem ,then test my phone is ok goodby
Old 09-29-2012, 19:55   #13 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
Boot mode: CC
Programming ...
Programming ...
Programming ...
Checksum failed
Programming ...
Checksum failed
Programming ...
Checksum failed
Phone Type: RM-647
Ppm Id: IJ
Language Pack:
- not available.
Version:
Counter: 0/3, 0/10
mate first full phone info
check LCD unknown change phone lcd 100% ok
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Page generated in 0.23294 seconds with 9 queries
