Old 06-26-2011, 18:40   #1 (permalink)
Member: 1605139
Thanks Meter: 6
$15/€10/£10 to the one who solves this problem(ANWERED)
I will send through paypal to the person who can tell me the detailed steps to fix a tricky nokia N96. It has the "Contact retailer" problem. The steps have to work. If more than one person gives them I will send to the first. If you want, PM me for more details about the phone or anything else. Thanks.
Old 06-26-2011, 18:44   #2 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
if you have a good PM 120 back-up use the new function restore simlock from PM which is in 'IMEI & Security'->'IMEI Rebuild'->'Restore SIMLOCK'
Yassine
Old 06-26-2011, 18:49   #3 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
please poste log here to check where it probleme
if have teamviwer instaler pm me id and password
Old 06-26-2011, 18:51   #4 (permalink)
Member: 1605139
Thanks Meter: 6
I don't have backups. I got the phone like that. Can I use from another n96?And can you tell me which tools would I need (box, sw)?
Thanks
Old 06-26-2011, 18:55   #5 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
1-write good pm with sx4 & removed 308
2- reset all
tested by me 100%%
Old 06-26-2011, 18:58   #6 (permalink)
Member: 1605139
Thanks Meter: 6
Here is the log:
-> MCU SW version: V ICPR72_09w13.2
19-05-09
RM-247
(c) Nokia
-> HW version: 1001
-> PCI version:
-> RFIC version:
-> DSP version:
-> Retu version: 15
-> Tahvo version: 22
-> Production serial number: CHH036713
-> Product code: 0572092
-> Module code:
-> Basic production code: 0542934
-> Flash code:
-> Order number:
-> Product specific data:
-> Long production SN: 0
-> ATO:
-> Default SN type:
-> IMEI plain: --
-> IMEI spare to net: --
-> IMEI SV to net: --
LOCK STATUS:
CONFIG KEY: 0000000000000000
-> PROVIDER KEY: 0000000000000000
-> Provider: Unknown provider
-> Key Code count: 0, FBUS Code count: 0
I put -- instead of the imei.
I tried a solution which was on the forum (using the BB5Erase_universal_rapido.bin) and now it won't even go to local mode, it just keeps restarting.
What is teamviwer?
Old 06-26-2011, 18:58   #7 (permalink)
sameera's Avatar
Member: 189673
Sonork: 100.1592062
Thanks Meter: 351
contact with your near Nokia care center
Old 06-26-2011, 19:00   #8 (permalink)
Member: 1605139
Thanks Meter: 6
yassinek85 with which tools(box, sw)?
Old 06-26-2011, 19:06   #9 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
with mxkey or mx box
Old 06-26-2011, 19:10   #10 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
PM IS HERE N96_RM-247 usman.rar - 4shared.com - online file sharing and storage - download
IF YOU HAVE NOKIA N96 WITH SOME OPERADOR THIS WILL BE VERRY GOOD TO SOLVE YOUR PROBLEME
JUST READ PHOME FROM GOOD PHONE AND WRITE IT TO DAMAGE PHONE
Old 06-26-2011, 19:12   #11 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 415
Wink
Originally Posted by harjeev View Post
Here is the log:
19-05-09
RM-247
(c) Nokia
-> HW version: 1001
-> PCI version:
-> RFIC version:
-> DSP version:
-> Retu version: 15
-> Module code:
-> Flash code:
-> Order number:
-> ATO:
-> Default SN type:
-> IMEI plain: --
LOCK STATUS:
What is teamviwer?
I think that you will need to pay more than $15/€10/£10
since I think your imei is coruped and you have to buy RPL
Old 06-26-2011, 19:13   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
please use MXKEY.
IMEI plain: --
tampered phone without backup: buy factory rpl.
Old 06-26-2011, 19:17   #13 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
If imei is good no need to pay for rpl
Old 06-26-2011, 19:36   #14 (permalink)
Member: 1605139
Thanks Meter: 6
The imei is fine (in the log). I replaced it with "--".
But as I said after trying to flash with the BB5Erase_universal_rapido.bin the phone now won't go to local mode and I can't do anything with it. Are those solutions still possible?
Old 06-26-2011, 19:51   #15 (permalink)
Member: 275290
Thanks Meter: 50
use a good cable
scan the phone with mxkey or mxbox
and post the scanned infomations
dont hide all the 15 digit of the imei, you can show 1st 8 digit or the last
show the full info.
security test
superdongle
etc
then i can solved the problem.
The Following User Says Thank You to alhudah_1 For This Useful Post:
Page generated in 0.18128 seconds with 9 queries
