05-29-2010, 05:22 | #1 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india Age: 41
Member: 664681 Status: Offline Thanks Meter: 53 | 1600 config_data: Ffffffffffffffff SW Version: V 7.02 10-12-07 RH-64 (c) NMP Imei plain: 35457401421724-0 Product Code: 0525434 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: N[G Language Pack: - not available. Imei net: 35457401421724 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 |
05-29-2010, 06:12 | #4 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
only unlock by old mathod | |
The Following User Says Thank You to cel_phon For This Useful Post: |
05-29-2010, 06:44 | #5 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | new method: imei & security > simlock : tick direct unlock --phone will permanently repaired/unlocked after flash. old method is patch, it will go to previous condition after reflash. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
05-29-2010, 07:00 | #6 (permalink) |
Member: 664681 Status: Offline Thanks Meter: 53 | Imei net: 35457401421724 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 [CR1]DCT4PLUS remaining credit: 43 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-64_35457401421724_SIM.RPL" Updating SIMLOCK ...ERROR: 01 Reading Simlock info ... Imei net: 35457401421724 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED same problem...........plz help me.......... |
05-29-2010, 07:14 | #8 (permalink) |
Member: 664681 Status: Offline Thanks Meter: 53 | ok old method.........unlock Imei net: 35457401421724 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 [CR1]DCT4PLUS remaining credit: 42 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RH-64_35457401421724_SIM.RPL" Updating SIMLOCK ...ERROR: 01 Reading Simlock info ... Imei net: 35457401421724 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000000000 BLOCK 1: 1.CORRUPTED |
05-29-2010, 07:16 | #9 (permalink) |
Member: 664681 Status: Offline Thanks Meter: 53 | Writing PM from Node ... Section: 1 - Key: 0, size 120 bytes written. - Key: 2, size 90 bytes written. - Key: 4, size 110 bytes written. - Key: 5, size 2 bytes written. - Key: 6, size 90 bytes written. - Key: 11, size 2 bytes written. Section: 2 - Key: 0, size 132 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 8 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 7 - Key: 0, size 4 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 4 bytes written. Section: 21 Warning: failed to write 21 - 0 (8 bytes) Warning: failed to write 21 - 1 (8 bytes) Warning: failed to write 21 - 2 (8 bytes) Warning: failed to write 21 - 3 (2 bytes) Warning: failed to write 21 - 4 (928 bytes) Warning: failed to write 21 - 5 (1 bytes) Warning: failed to write 21 - 6 (8 bytes) Section: 26 - Key: 0, size 302 bytes written. - Key: 1, size 302 bytes written. - Key: 2, size 302 bytes written. - Key: 3, size 302 bytes written. - Key: 4, size 302 bytes written. - Key: 5, size 302 bytes written. - Key: 6, size 302 bytes written. Section: 120 Warning: failed to write 120 - 0 (78 bytes) Completed in 4.578 s |
05-29-2010, 07:21 | #10 (permalink) | |
Insane Poster Join Date: Mar 2008
Member: 721821 Status: Offline Thanks Meter: 10 | Quote:
flash the phone what ever you like to use like JAF , UFS , or MXKEY then write GOOD PM USE UFS..... after write good pm UNLOCK YOUR PHONE USE MXKEY THAT IT THE PHONE WILL FIX | |
The Following User Says Thank You to josh_ploy For This Useful Post: |
downloading polyringtones for 1600 with cable | magnet | LG | 0 | 02-07-2005 07:15 |
LG 1600 pinouts | Mitya | LG | 0 | 09-13-2004 20:50 |
Who knows charger pinout for Qualcomm GSP-1600 Satellite phone? | dimka | Hardware Repair by brands | 0 | 03-31-2002 21:00 |
3200 LOGS 1600 Picture Messages | GM | GSM Mobile Links | 0 | 02-09-2001 14:06 |
3200 LOGOS and 1600 PICTURE Messages | GM | GSM Mobile Links | 0 | 02-06-2001 17:58 |
