02-22-2010, 08:51 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | 1600 imei ? here is log ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0095078A:2984DA60 Trying to find patch position ...Ok, found in 11.438 s Not supported firmware. Error while processing command ! |
02-22-2010, 08:58 | #2 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | with uncheck patch software option here is log ASIC type: 2 UEM Imei: 35365001748072 Flash Imei: 35478765867654 Writing new imei ... ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0095078A:2984DA60 New imei written. Phone Type: RH-64 SW Version: V 5.53 20-07-06 RH-64 (c) NMP Imei plain: ??????????????-? Product Code: 0525376 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: E2443EAD5B4694B6 PROFILE_BITS: 3E1213184400CD3A Imei net is empty, process aborted. the imei is corrupted now |
02-22-2010, 09:03 | #4 (permalink) |
Member: 303790 Status: Offline Thanks Meter: 290 | now the imei change successfully but the signals gone after 30 secands here is log ASIC type: 2 UEM Imei: 35365001748072 Flash Imei: 35478765867654 Writing new imei ... ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0095078A:2984DA60 New imei written. Phone Type: RH-64 SW Version: V 5.53 20-07-06 RH-64 (c) NMP Imei plain: 35365001748072-9 Product Code: 0525376 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu Imei net: 35365001748072 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Updating SIMLOCK ...OK any one test with perfect solution |
02-22-2010, 09:11 | #7 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | 1110 <---------------- RH-70<---------------0526-------------------V5.03,V5.53,V6.40 1112 <---------------- RH-93<---------------0502,0526,0536-------V5.03,V5.50,V6.40 1112B<----------------RH-92<---------------2201------------------V5.03 1600 <---------------- RH-64<---------------0526,0529<------------V5.53,V6.00,V6.40 1600B<----------------RH-65<---------------0529 <-----------------V5.03 2310 <---------------- RM-189<--------------0526,0531<------------V3.31,V5.10,V5.90 ,V6.30 2610 <---------------- RH-86<---------------0601 <----------------V3.77,V5.23, 5.65 2626 <---------------- RM-291<--------------2002,2502,0501,0601,<---V 03.51,V4.61 2630 <---------------- RM-298 <--------------1001,2000 <-----------V3.82,V5.20 2760 <---------------- RM-259 <-------------- 2503 <-----------V03.62 3220 <---------------- RH-37<---------------5053,6203 <-----------V03.30,v5.90 5070 <---------------- RM-167<--------------4012 <----------------V4.20 6020 <---------------- RM-30<---------------5001,5051 <----------------V 04.90,V5.20 6030 <---------------- RM-74<---------------0702 <----------------V4.11,V511 6080 <---------------- RM-166<--------------4051 <----------------V4.22 6101 <---------------- RM-77 <--------------5000 <----------------V3.38 6103 <---------------- RM-162<--------------4006 <----------------V4.61 match ur id this is important.if u want to repair u must know about match id |
02-22-2010, 09:28 | #9 (permalink) | |
Member: 303790 Status: Offline Thanks Meter: 290 | Quote:
RH-64<---------------0526 with supported version | |
02-22-2010, 09:45 | #11 (permalink) | |
2ndly please please read the previously post care fully 3rd i think you will laugh on your self | |
02-22-2010, 09:59 | #13 (permalink) |
Member: 405696 Status: Offline Thanks Meter: 148 | ur imei stolen block 35365001748072-9 if not block i leave forummmmmmmmmmmm check ur imei brother and me also write sorry. this imei block pta. so just change imei ur problem solve |
help 1600 imei ????????????.. | Rinaldo | UFS2 + UFS3-Tornadoflasher | 4 | 12-03-2010 19:41 |
1600 imei ????? someone calculate my 1600 | julmars | Phone Unlocking Codes & Maps | 2 | 04-26-2009 03:58 |
nokia 1600 imei | jacob magembe | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 09-16-2006 12:07 |
1600 imei ????????4 | Rinaldo | UFS2 + UFS3-Tornadoflasher | 6 | 04-28-2006 10:52 |
