10-06-2012, 16:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Post Buscheck Logs, If Logs Ok then check LCD ways or Change LCD will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-06-2012, 17:14 | #3 (permalink) |
Crazy Poster Join Date: Sep 2009
Member: 1118992 Status: Offline Sonork: 100.1622295 Thanks Meter: 3 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C086D45D Using device: HTI, FW ver: 00.50, SN: 00016640 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Device synchronized. CPU: XGOLD 110 Using embedded SBL from MCU. Sending EBL Loader ...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.19 EBL version: Default_RAM_Bootloader Set baud rate to: 921.60 Kbit/s Flash ID: 00EC 2254 - 23280002 [Samsung K8S6415ETC,64 Mbits] CFI information: Flash settings: 0/1, size: 0x00800000 2 Block regions: 127 x 0x00010000 = 0x007F0000 8 x 0x00002000 = 0x00010000 EBL ready ! Phone type: RH-125 SW version: V 06.51 13-05-11 RH-125 (c) Nokia Imei plain: 35201704825439-3 Product code: 0595840 Cellular system: GSM ASIC ID: 0x2292, type: 11 Ppm Id: MG Language Pack: English,Hindi,Marathi Imei net: 35201704825439 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
10-06-2012, 18:24 | #4 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
10-06-2012, 19:59 | #5 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: jodhpur india Age: 41
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | Quote:
check bsi line by mobile care | |
The Following User Says Thank You to imrankhan0143 For This Useful Post: |
