Old 06-07-2011, 07:06   #1 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
1616 Checksum mismatch (SOLVED)
MXKEY Serial: [FT SCR2000 0] - xxxxxxxxx
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 1.6.6.0, NTMP ver: 1.6.6.1
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921600
Flash ID: 0020 80C0 [ST ]
Processing file: rh125_005.800
Downloading item CODE:hw_f11_rh125_r05.800.fls, num block: 3, size: 4.10 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 38.500 s
Erasing area 0x00C60000-0x00E6843E ...OK
Programming completed in 38.406 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.172 s
Checksum mismatch: Phone calculated 0xAF31, software calculated 0xEB6C
Processing file: rh125_005.80mr
Downloading item CUST:hw_f11_rh125_005.80mr.fls, num block: 1, size: 1.95 MB
Erasing area 0x00210000-0x004017BE ...OK
Programming completed in 36.797 s
Checksum mismatch: Phone calculated 0x8C23, software calculated 0x0DD8
Processing file: rh1250_nai05.80mr
Downloading item CUST:hw_f11_rh1250_nai05.80mr.fls, num block: 1, size: 297.33 KB
Erasing area 0x00EB0000-0x00EF983E ...OK
Programming completed in 5.829 s
Checksum mismatch: Phone calculated 0xC360, software calculated 0x155B
Total time for flashing process(boot+erase+write) was 3 min 41.391 s
Phone not responding !
Old 06-07-2011, 08:43   #2 (permalink)
GSMPAKHOST's Avatar
Member: 1516950
Sonork: 100.1593505
Thanks Meter: 5,748
Bro Its Lcd Problum 100%
try to change Lcd your Problum 100% solve.
& post result Here ................
Old 06-07-2011, 08:56   #3 (permalink)
Member: 392149
Sonork: 100.1597220
Thanks Meter: 197
Hey bro first flash your phone with latest firmware verion after that
take selftest and post resultz here
BR,
Old 06-07-2011, 09:01   #4 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Same problem with latest version 6.20
Can't flash,Checksum mismatch and Phone not responding !
Old 06-07-2011, 09:36   #5 (permalink)
Member: 392149
Sonork: 100.1597220
Thanks Meter: 197
Hi bro Checksum mismatch dosnt mater it is a bug the problem is phone not responding chek ur cable anf flash files and make sure ur cable quilty
is good if not succes then use MX box
BR,
Old 06-07-2011, 09:49   #6 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
I have flashed so many phones with this cable and interface,
as I think that is not cable and interface problem.
Old 06-07-2011, 09:54   #7 (permalink)
Member: 392149
Sonork: 100.1597220
Thanks Meter: 197
Bro what condition is phone befor flashing
BR,
Old 06-07-2011, 10:03   #8 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Set is come in dead condition,it was not showing info,
Therefore i flash it.
Old 06-07-2011, 10:07   #9 (permalink)
Member: 392149
Sonork: 100.1597220
Thanks Meter: 197
Bro then it is Hardware problem open ur phone and saw the board
condition and chek ur phone in HW
BR,
Old 06-07-2011, 10:16   #10 (permalink)
Member: 802910
Thanks Meter: 28
Try to flash with HWK
It will b solved. Tested by me
Old 06-07-2011, 10:28   #11 (permalink)
GSMPAKHOST's Avatar
Member: 1516950
Sonork: 100.1593505
Thanks Meter: 5,748
Its 100% Hardware problum.......................
The Following User Says Thank You to GSMPAKHOST For This Useful Post:
Old 06-07-2011, 15:09   #12 (permalink)
Member: 959010
Sonork: 100.1602440
Thanks Meter: 445
Thank you problem solved after hardware repair and flashing with mxkey
1.Reball flash chip and cpu if same
2.Reball and little shake cpu very carefully
3.Flash
CPU: XGOLD 110
Sending EBL ...OK
Boot mode: 0xCC
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rh125_006.200
Downloading item CODE:hw_f11_rh125_r06.200.fls, num block: 3, size: 4.10 MB
Programming completed in 41.235 s
Erasing area 0x00C60000-0x00E6983E ...OK
Programming completed in 40.968 s
Programming completed in 0.156 s
Checksum verified (0x02AD)
Processing file: rh125_006.20ej
Downloading item CUST:hw_f11_rh125_006.20ej.fls, num block: 1, size: 2.01 MB
Erasing area 0x00210000-0x004124FE ...OK
Programming completed in 38.891 s
Checksum verified (0xC722)
Processing file: rh1250_nai06.20ej
Downloading item CUST:hw_f11_rh1250_nai06.20ej.fls, num block: 1, size: 320.45 KB
Erasing area 0x00EB0000-0x00EFF4BE ...OK
Programming completed in 6.265 s
Checksum verified (0x2F12)
Total time for flashing process(boot+erase+write) was 3 min 30.546 s
Phone Type: RH-125
SW Version: V 06.20 01-12-10 RH-125 (c) Nokia
Imei plain: 355368XXXXXXX
Product Code: 0590493
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: EJ
Language Pack:
English,Russian,Ukrainian
Imei net: 35536XXXXXXX
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
The Following User Says Thank You to madni shah For This Useful Post:
6150 checksum brka1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-21-2001 11:56
Checksum Cyberdog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 04-09-2001 20:34
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 01-02-2001 11:55
New!! Nokia Flash Checksum And Contact Service Repair HookerGsM Main Sales Section 0 01-02-2001 09:12
checksum calculation? pilcris Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-06-2000 10:16
Page generated in 0.89062 seconds with 8 queries
