12-08-2010, 11:16 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | 1616 Flash OK but no Power On Checksum failed Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r03.610.fls from file rh125_003.610 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 34.875 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 32.078 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum failed Processing CUST:hw_f11_rh125_003.61ej.fls from file rh125_003.61ej Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 29.312 s Checksum failed Processing CUST:hw_f11_rh1250_nai03.61ej.fls from file rh1250_nai03.61ej Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 4.687 s Checksum failed Flashing completed in 3 min 27.719 s Phone Type: RH-125 SW Version: V 03.61 29-01-10 RH-125 (c) Nokia Imei plain: 35375104470538-3 Product Code: 0588620 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: EJ Language Pack: - not available. Imei net: 35375104470538 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
12-08-2010, 12:04 | #3 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Again same problem Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK BootloaderString: SE0_091125 F11 Boot mode: CC EBL version: 10.13, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r05.800.fls from file rh125_005.800 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 34.735 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 33.985 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.031 s Checksum failed Processing CUST:hw_f11_rh125_005.80ij.fls from file rh125_005.80ij Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 30.844 s Checksum failed Processing CUST:hw_f11_rh1250_nai05.80ij.fls from file rh1250_nai05.80ij Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 5.454 s Checksum failed Flashing completed in 3 min 32.172 s Phone Type: RH-125 SW Version: V 05.80 06-08-10 RH-125 (c) Nokia Imei plain: 35375104470538-3 Product Code: 0588620 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IJ Language Pack: - not available. Imei net: 35375104470538 Version: Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
