Old 03-10-2011, 07:53   #1 (permalink)
ecs_lk's Avatar
Member: 358337
Thanks Meter: 46
1616 water damage error flashing
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
BLS (EPOCH,DATE,KEYFIX): SE0_091125 F11
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921600
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rh125_005.800
Downloading item CODE:hw_f11_rh125_r05.800.fls size: 4.10 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 38.953 s
Erasing area 0x00C60000-0x00E6843E ...OK
Programming completed in 39.406 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.141 s
Error reading checksum!
Processing file: rh125_005.80mf
Downloading item CUST:hw_f11_rh125_005.80mf.fls size: 2.17 MB
Erasing area 0x00210000-0x0043ADBE ...OK
Programming completed in 36.140 s
Checksum mismatch: Phone calculated 0x0044, software calculated 0x9B62
Processing file: rh1250_nai05.80mf
Downloading item CUST:hw_f11_rh1250_nai05.80mf.fls size: 301.08 KB
Erasing area 0x00EB0000-0x00EFA73E ...OK
Programming completed in 4.750 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0xE105
Total time for flashing process(boot+erase+write) was 3 min 35.640 s
Phone Type: RH-125
SW Version: V 05.80 06-08-10 RH-125 (c) Nokia
Imei plain: 35538904251323-2
Product Code: 0587507
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MF
Language Pack:
- not available.
Imei net: 35538904251323
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Old 03-10-2011, 18:22   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
so what is the problem? phone is scanned alive after flash.
Old 03-11-2011, 06:48   #3 (permalink)
ecs_lk's Avatar
Member: 358337
Thanks Meter: 46
Originally Posted by gbluez View Post
hi,
error was water damage no power phone error checksum when flash ,later i solved da prob, prob was bad lcd ,
now phone ok.....
tks for reply......
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.19048 seconds with 10 queries
