10-18-2010, 11:05 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: B A N G L A D E S H
Member: 324750 Status: Offline Sonork: 100.1590437 Thanks Meter: 302 | 1616_RH-125 Flashing Done But No Power. Hlp me (SOLVED) My uses Flash File ver.RH-125_dp_v_01_01_MCUSW03_60_F1.1 Flashing completed but No Power... Now What can i do ??????? Log, Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Do not disconnect or abort this operation otherwise phone will be damaged. Device synchronized. CPU ID: A200341100 [X-GOLD 110] Sending Primary Boot Loader ...OK Changing baudrate to: 921600 Sending Secondary Boot Loader ...OK Boot mode: CC EBL version: 10.19, Default_RAM_Bootloader Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits] Processing CODE:hw_f11_rh125_r03.600.fls from file rh125_003.600 Erasing area 0x00800000-0x00A0FFFE ...OK Programming ... Programming completed in 31.844 s Erasing area 0x00C60000-0x00EAFFFE ...OK Programming ... Programming completed in 30.500 s Erasing area 0x00FFC000-0x00FFFFFE ...OK Programming ... Programming completed in 0.047 s Checksum failed Processing CUST:hw_f11_rh125_003.60es.fls from file rh125_003.60es Erasing area 0x00210000-0x0045FFFE ...OK Programming ... Programming completed in 24.735 s Checksum failed Processing CUST:hw_f11_rh1250_nai03.60es.fls from file rh1250_nai03.60es Erasing area 0x00EB0000-0x00F7FFFE ...OK Programming ... Programming completed in 4.203 s Checksum failed Flashing completed in 3 min 20.469 s Phone Type: RH-125 SW Version: V 03.60 15-01-10 RH-125 (c) Nokia Imei plain: 35201704044191-5 Product Code: 0587509 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: ES Language Pack: - not available. Imei net: 35201704044191 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000030002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Total time to process is 3 min 27.656 s Thanks Hossne Mamun |
The Following User Says Thank You to hossnemamun For This Useful Post: |
10-18-2010, 11:19 | #3 (permalink) |
No Life Poster Join Date: Apr 2010 Location: United Arab Emirates ( DUBAI )
Member: 1294044 Status: Offline Thanks Meter: 1,269 | helllo br plz Check SELF TESTS Lcd fald chang lcd & post rapot thanks ::BR:: ..::KASHIF::.. |
The Following 2 Users Say Thank You to ..::KASHIF::.. For This Useful Post: |
10-18-2010, 12:03 | #5 (permalink) | |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Quote:
download this version and flash this file i hope u r set is alive 1616 RH-125 v.05.80 BI ONLY Upload Julianto0610.rar - 4shared.com - online file sharing and storage - download 1616_RH-125_5.80_AR.zip - 4shared.com - online file sharing and storage - download B.R............................ SAQIB-TARBELA-GHAZI | |
The Following User Says Thank You to saqib2009 For This Useful Post: |
10-18-2010, 12:50 | #6 (permalink) |
Member: 324750 Status: Offline Sonork: 100.1590437 Thanks Meter: 302 | Dear Bro, LCD is ok. That's Tested LCD.. Then I tried to Re hit PCB. problem is still. Now What can i do???? Thanks Hossne Mamun |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
