03-25-2011, 19:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: morocco Age: 39
Member: 243158 Status: Offline Thanks Meter: 25 | 1650 erreur flash Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007D1CBA3BDA66 ASIC type: 11 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\0044010106565 6_BA CK.rpl" Processing MCU file: rm305_06.000 [DCT4,DCT4 ALGORITHM] size: 2.33 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007D1CB:2984DA60 Area [01000000-0100FFFF] erased in 0.812 s Area [01010000-0179FFFF] erased in 1 min 3.734 s Area [017A0000-017EFFFF] erased in 2.906 s Area [01F00000-01FDFFFF] erased in 0.078 s Flash programming ... Programming completed in 24.016 s File Processed in 1 min 40.813 s Processing CNT file: rm3050_nai6.00ic [DCT4,DCT4 ALGORITHM] size: 186.92 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007D1CB:2984DA60 Area [01760000-0179FFFF] erased in 2.187 s Flash programming ... Programming completed in 1.875 s Content extract fail, continue anyway ... File Processed in 47.297 s Processing PPM file: rm305_06.00ic [DCT4,DCT4 ALGORITHM] size: 2.53 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0007D1CB:2984DA60 Area [01240000-0125FFFF] erased in 1.078 s Area [01260000-0175FFFF] erased in 42.203 s Flash programming ... Programming completed in 25.671 s File Processed in 1 min 19.968 s Total time for flashing process(boot+erase+write) was 3 min 48.109 s Phone not responding |
03-27-2011, 09:20 | #3 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | Quote:
03-27-2011, 14:15 | #5 (permalink) | |
Member: 243158 Status: Offline Thanks Meter: 25 | Quote:
MCU ID: 0x2292 FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.000 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.000 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.00ic CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French,Swahili Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.000 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.00ic CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai6.00ic ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French,Swahili MCU: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.000 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 36 Loader is ready... P-key nokia module version 01.02 MSID: 84F4FE1A465CE596EFD84BD1E8 MSID decoded: 3E4EBAE9001F22CCA9000000 FAID: A39D955C9F09964FEEE696B8 Operation took 0 minutes 11 seconds... Erasing... Found 4 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 0179FFFF... Erasing area: 017A0000 - 017EFFFF... Erasing area: 01F00000 - 01FDFFFF... Operation took 1 minutes 16 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 14 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_06.00ic Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 36 Loader is ready... P-key nokia module version 01.02 MSID: 849AE380E9CE849135CAD6BCFF MSID decoded: 3E4EBAE9001F22CCA8000000 FAID: 2C6DBABDCCC6B4FBC52038FF Operation took 0 minutes 10 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0125FFFF... Erasing area: 01260000 - 0175FFFF... Operation took 0 minutes 48 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 15 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai6.00ic Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xC0882000 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x4B38; Loader chk: 36 Loader is ready... P-key nokia module version 01.02 MSID: 84F4FE1A465CE596EFD84BD1E8 MSID decoded: 3E4EBAE9001F22CCA9000000 FAID: A39D955C9F09964FEEE696B8 Operation took 0 minutes 10 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01760000 - 0179FFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 3 minutes 12 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! | |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Nokia Flash Content. | Phantom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-01-2000 23:28 |
