03-28-2010, 14:25 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2004 Location: Bangladesh Age: 44
Member: 54228 Status: Offline Thanks Meter: 76 | 1650 SIMLOCK_DATA corrupted (ANSWERED) SW Version: V 5.71 12-09-08 RM-305 (c) NMP Imei plain: 35291202235226-4 Product Code: 0553140 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MJ Language Pack: - not available. Failed to read SP data i try 1.Full eras 2.full flash 3.Write pm but same problem |
The Following User Says Thank You to biddut1979 For This Useful Post: |
03-28-2010, 14:27 | #2 (permalink) |
No Life Poster Join Date: Nov 2008 Location: saudi arabia
Member: 904809 Status: Offline Sonork: 100.1615464 Thanks Meter: 738 | try 2 unlcok, simlock is damage,,unlocking is solution,,post result. |
The Following User Says Thank You to alkhaleejmobile For This Useful Post: |
03-28-2010, 16:16 | #7 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: LOVE A L L AH LOVE ALQURAN
Member: 754324 Status: Offline Sonork: LOVE MOHAMMAD (S.A.W) Thanks Meter: 500 | Quote:
02-14-2011, 17:56 | #10 (permalink) |
Freak Poster Join Date: Feb 2008 Location: india
Member: 712150 Status: Offline Thanks Meter: 31 | i am reball flesh . then 1650 goes to failed to read sp data i am useing ufs 3 result MCU SW : V 6.00 30-09-09 RM-305 (c) NMP PPM SW : V 6.00 30-09-09 RM-305 (c) NMP IA Prd.Code: 0547535 Bpr.Code: 0515495 Prod.Sn : DMR262460 HW Vers : 1501 UEM : 1328 UPP : 8850 [2292] RFIC Ver: DSP Vers: LCD Type: UNKWN: IDs: 00:ff:00 IMEI : 356825-02-346224-5 SL Conf : 000-00-00000000000 SL Prof : 000000000000000-0 SL Var : 140C00000000014003E7 SL Aux : 00000000 Box Id : 0000000001410FE0 SL Data Corrupted i am useing mt result Phone is in: Local mode Model: RM-305 (1650) V 6.00/30-09-09/RM-305 (c) NMP Production serial number DMR262460 Product code 0547535 Module code 0203271 Basic production code 0515495 Flash code Order number Long production SN MCU SW V 6.00/30-09-09/RM-305/(c) NMP HW 1501 PCI UEM 1328 UPP 8850 LCD UNKWN: IDs:/00:ff:00 PPM V 6.00/30-09-09/RM-305/(c) NMP/IA ADSP SW p&V 6.00\n30-09-09\nRM-305\n(c) NMP\nia IMEI: 356825023462245 WARNING: VPP pin is not connected, disabling VPP. Phone is in: Normal mode Phone SelfTest status: Passed: UEM_CBUS_IF Passed: SLEEP_X_LOOP Passed: EAR_DATA_LOOP Passed: SIM_CLK_LOOP Passed: SIM_IO_CTRL_LOOP Passed: WARRANTY Passed: SIM_LOCK Passed: PPM_VALIDITY Fail: LCD NotExecuted: FLASH_CHECKSUM NotExecuted: RF_CHIP_ID NotExecuted: KASUMI Summary: Passed(8), NotExucuted(3), OtherStatus(1) V 6.00/30-09-09/RM-305 (c) NMP IMEI: 356825023462245 Failed to Read VPP is DISABLED. Using Tx2 Data line. Processing File: rm305_06.000 Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_intel.fia 847DD825D0F557D59B60B8B5693F Configuration Info (9F): Number of Flashes: 2 01000000: Intel, 0089 8874 0000 7121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[8.81 MB]... erasing region [01000000 to 0100FFFF] erasing region [01010000 to 0179FFFF] erasing region [017A0000 to 017EFFFF] erasing region [01F00000 to 01FDFFFF] in 75.19s Flash[2.33 MB]...in 18.45s * * Processed file in 101.77 seconds Processing File: rm3050_nai6.00ia Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_intel.fia 847DD825D0F557D59B60B8B5693F Configuration Info (9F): Number of Flashes: 2 01000000: Intel, 0089 8874 0000 7121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[0.25 MB]... erasing region [01760000 to 0179FFFF] in 2.36s Flash[0.16 MB]...in 1.24s * * Processed file in 11.70 seconds Extract content...OK Processing File: rm305_06.00ia Boot... ASIC ID: 2292 DCT4 u3_2nd.fia u3_intel.fia 84865093388877B8ECE09B8DB47B Configuration Info (9F): Number of Flashes: 2 01000000: Intel, 0089 8874 0000 7121, 10 02000000: NotUsed, 0000 0001 0000 0000, 0 ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Erase[5.12 MB]... erasing region [01240000 to 0125FFFF] erasing region [01260000 to 0175FFFF] in 47.67s Flash[2.71 MB]...in 21.42s * * Processed file in 77.22 seconds * * * Phone flashing done in 3:18 minutes Post Flash serial tunning of phone.... Pooling mode for full factory set... V 6.00/30-09-09/RM-305 (c) NMP IMEI: 356825023462245 Factory Default Settings...OK V 6.00/30-09-09/RM-305 (c) NMP IMEI: 356825023462245 Failed to Read i am again mx key result Using device: MTBOX, CR ver: 1.02.0100 Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0049354CA3BDA66 ASIC type: 11 UEM Imei: 35682502346224 Processing MCU file: rm305_06.000 [DCT4,DCT4 ALGORITHM] size: 2.33 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0049354C:2984DA60 Area [01000000-0100FFFF] erased in 0.578 s Area [01010000-0179FFFF] erased in 1 min 11.047 s Area [017A0000-017EFFFF] erased in 3.375 s Area [01F00000-01FDFFFF] erased in 0.172 s Flash programming ... Programming completed in 19.641 s File Processed in 1 min 41.203 s Processing CNT file: rm3050_nai6.00mg [DCT4,DCT4 ALGORITHM] size: 180.34 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0049354C:2984DA60 Area [01760000-0179FFFF] erased in 2.344 s Flash programming ... Programming completed in 1.547 s Extracting Content Pack, File Server fake reply for CUI phone. Content Pack extracted successfully in 0.109 s File Processed in 18.297 s Processing PPM file: rm305_06.00mg [DCT4,DCT4 ALGORITHM] size: 3.52 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.80.0 revision: 0.7 size: 0x5720 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0049354C:2984DA60 Area [01240000-0125FFFF] erased in 1.172 s Area [01260000-0175FFFF] erased in 46.812 s Flash programming ... Programming completed in 29.547 s File Processed in 1 min 24.063 s Total time for flashing process(boot+erase+write) was 3 min 23.594 s Phone Type: RM-305 SW Version: V 6.00 30-09-09 RM-305 (c) NMP Imei plain: 35682502346224-5 Cellular System: GSM ASIC ID: 0x2292, type: 0 Ppm Id: MG Language Pack: - not available. Failed to read SP data any body know whats the problem & its soln |
02-14-2011, 18:28 | #11 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | @vivek: what is the phone condition? from self test, lcd not detected properly. to full rebuild any dct4: - reset data1 - erase get address, untick safe erase, erase. - reflash, proceed with rpl rebuild by online logger dct4plus imei. - write pm, skip all simlock overwrite. i already write about this some where... |
Corrupted eeprom data in 3210 | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 03-02-2002 04:58 |
Nokia 8890 Ver.12.07 Software Corrupt or What? | mobileguru | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-18-2002 16:56 |
What to do if EEPROM is corrupted? | Nick-A | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 01-08-2002 08:50 |
dead 3310 due to corrupt fullflash | ambot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-14-2001 17:10 |
GEOS.INI file has been corrupted | amana24 | Hardware Equipments for GSM | 1 | 11-14-2001 11:04 |
