Old 07-29-2010, 07:59   #1 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
1661-2b rh-121 no signal
hi all, i have nokia 1661-2b rh121 with 01218800 imei, it did't show signals after unlock,is there any tested solution available for that problem,
if yes then plz share,
thanx
The Following User Says Thank You to zeeshan tayyab For This Useful Post:
Old 07-29-2010, 09:38   #2 (permalink)
redrose2009's Avatar
Member: 1084993
Sonork: 100.1617420
Thanks Meter: 641
flash with rh122 firmware and write rh122 pm file your problem will be solved tested 10 mobiles working fine 100%
The Following User Says Thank You to redrose2009 For This Useful Post:
Old 07-30-2010, 05:58   #3 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
thanx
bro, its work with 850/1900 band
for 900/1800 band u need change filter, and write a good pm file.
Old 07-30-2010, 08:17   #4 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
thanx
here is 100 % working solution ........tested by me
http://forum.gsmhosting.com/vbb/f139...011-a-1057816/
The Following User Says Thank You to mohit_kripalu01 For This Useful Post:
5110v5.29 no network GSMlearner Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 04-08-2001 17:15
Dejans Flasher Problem with 6150, NO Network after Flashing AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-03-2001 22:39
My 6150 (5.23) No network after Flashing AboAli Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-31-2001 15:56
6150 no outgoing calls edis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-20-2000 20:19
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.16720 seconds with 9 queries
