05-10-2010, 18:41 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 47
Member: 134892 Status: Offline Thanks Meter: 18 | 1661 contact servece plez help Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0009042BA3BDA66 ASIC type: 11 UEM Imei: 35832203911973 Flash Imei: 35832203911973 MasterCode: 4436233456 RPL saved to "C:\mobileEx\3.4\data\backup\35832203911973_BACK.r pl" Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35832203911973-6 Product Code: 0569745 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: IC Language Pack: - not available. TimeStamp: 2009-07-01T04:05:58Z SW Version: 04.03 Variant Version: 001 ProductProfile: RH112_0569745_04.03_001.spr Simlock: 0569745_SimLockDataVerifier_vDCT4.sim Failed to read SP data Failed to read SP data Failed to read SP data |
The Following User Says Thank You to sary For This Useful Post: |
05-10-2010, 19:06 | #4 (permalink) |
Member: 134892 Status: Offline Thanks Meter: 18 | SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0009042BA3BDA66 ASIC type: 11 UEM Imei: 35832203911973 Flash Imei: 35832203911973 MasterCode: 4436233456 RPL saved to "C:\mobileEx\3.4\data\backup\35832203911973_BA CK.r pl" Phone Type: RH-112 SW Version: V 03.10 21-01-09 RH-112 (c) NMP Imei plain: 35832203911973-6 Product Code: 0569745 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: IC Language Pack: - not available. TimeStamp: 2009-07-01T04:05:58Z SW Version: 04.03 Variant Version: 001 ProductProfile: RH112_0569745_04.03_001.spr Simlock: 0569745_SimLockDataVerifier_vDCT4.sim Failed to read SP data |
05-10-2010, 19:45 | #7 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Guangzhou-China
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | Just: Manuel calculate RPL ----> Write RPL ----> Direct ulock. if not: flash mobile---> Write RPL ----> Direct ulock. *Post result. |
The Following User Says Thank You to MOURAD™ For This Useful Post: |
05-11-2010, 16:14 | #13 (permalink) |
Member: 468587 Status: Offline Sonork: 100.1612429 Thanks Meter: 681 | are write rpl ok? coz your problem here: Code: ASIC ID: 0x2293, type: 0 Code: ASIC ID: 0x2293, type: 11 |
05-12-2010, 07:01 | #14 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | 1661 contact service 100% this is HRW PROBLAM full het up flish ic and uem 100% 1661 contact service 100% canfaram i try........................... |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
