04-01-2010, 19:42 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | 1661 imei problem ( i flash yhe fone v3.00 ver 3.10) Phone Type: RH-121 SW Version: V 03.10 02-11-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Failed to read SP data log online logger dct4+ imei: ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 Connecting to server ...OK, Login ... Hello C08067FF, you have 2000 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\01188500219186.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
04-01-2010, 21:58 | #2 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 Connecting to server ...OK, Login ... Hello C08067FF, you have 2000 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\0118850021918 6.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UB Language Pack: - not available. |
04-04-2010, 16:25 | #12 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 Connecting to server ...OK, Login ... Hello C08067FF, you have 2000 credits left. RPL saved to "C:\mobileEx\3.3\data\backup\RPL\01188500219186.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UB Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
04-04-2010, 16:32 | #13 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Adilabad
Member: 890104 Status: Offline Sonork: 100.1597567 Thanks Meter: 138 | RPL saved to "C:\mobileEx\3.3\data\backup\RPL\0118850021918 6.RP L" This IMEI is not valid 100% UEM ic problem if your imei is correct u r posting wrong for security reason then try to write with jaf ihave also same problems thanks |
04-04-2010, 16:49 | #14 (permalink) | |
Member: 195225 Status: Offline Thanks Meter: 94 | Quote:
the imei made in maxico all imei star 01 not 35 . | |
06-28-2010, 07:36 | #15 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 367718 Status: Offline Thanks Meter: 14 | It is not uem problem, its Ur knowledge problem, uem was good, before flashing................................ RPL saved to "D:\mobileEx\3.4\fff\data\backup\RPL\BFDBFC83B3B8F 8.RPL" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00A86375A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ... UEM programmed successfully. Phone Type: RM-524 SW Version: V 05.01 23-09-09 RM-524 (c) Nokia Imei plain: ??????????????-? Product Code: 0578324 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: IA Language Pack: - not available. |
1661 imei chang?????? | mobiletuch | Nokia Hardware & Hardware Repair | 1 | 06-09-2010 09:32 |
1661 imei chang possible?? jaf | mobiletuch | Nokia Hardware & Hardware Repair | 19 | 06-09-2010 09:29 |
1661 imei problem | bsat | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 10 | 04-03-2010 02:53 |
122 1661 imei & simloks | kamal dhiman | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-13-2010 11:14 |
1661 imei | software.usm | Universalbox | 6 | 10-29-2009 08:39 |
