10-04-2009, 09:40 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | 1661 rh-122 UNLOCK FAILED tried with ufs & jaf interface both always phone not responding Imei net: 01188500047946 Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 310160 BLOCK 2: 1.LOCKED (MCC+MNC): 310200 BLOCK 3: 1.LOCKED (MCC+MNC): 310210 BLOCK 4: 1.LOCKED (MCC+MNC): 310220 BLOCK 5: 1.LOCKED (MCC+MNC): 310230 BLOCK 6: 1.LOCKED (MCC+MNC): 310240 BLOCK 7: 1.LOCKED (MCC+MNC): 310250 BLOCK 8: 1.LOCKED (MCC+MNC): 310260 BLOCK 9: 1.LOCKED (MCC+MNC): 310270 BLOCK 10: 1.LOCKED (MCC+MNC): 310310 BLOCK 11: 1.LOCKED (MCC+MNC): 310580 BLOCK 12: 1.LOCKED (MCC+MNC): 310660 BLOCK 13: 1.LOCKED (MCC+MNC): 310800 BLOCK 14: 1.LOCKED (MCC+MNC): 310490 PhoneType:RH-122 SwVersion: V 04.30 06-07-09 RH-122 (c) Nokia MCU file: rh122_004.300 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0056C643A3BDA66 Area [01000000-0101FFFF] erased in 1.578 s Area [01160000-0117FFFF] erased in 1.594 s Programming ... Programming completed. Phone not responding ! |
The Following User Says Thank You to himanshu taldar For This Useful Post: |
10-05-2009, 08:33 | #7 (permalink) | |
Freak Poster Join Date: May 2008
Member: 767451 Status: Offline Thanks Meter: 178 | Quote:
How is unlock 1661 rh-122 | tornado2008 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 11-15-2011 08:40 |
nokia 1661 rh 122 unlock problem | kamal07 | Nokia Hardware & Hardware Repair | 1 | 09-24-2009 17:30 |
1661-2 RH-122 Unlock error / ASIC not supported | paullovinicius | HWK | 2 | 06-17-2009 08:41 |
1661 RH-122 unlock | Eliran_EBL | HWK | 1 | 05-08-2009 16:38 |
1661 RH-122 unlock | Eliran_EBL | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-08-2009 01:19 |
