Old 02-10-2010, 13:21   #1 (permalink)
Member: 609820
Thanks Meter: 6
1661 unlock problem pls
hello
1661 mx key unlock problem
error 0x14
Imei net: 3582xxxxxxxxxxx
Version: SIMLOCK SERVER
Provider: Vodafone D2 (DCT4), Country: Germany
Counter: 0/3, 0/10
CONFIG_DATA: 2620200000000000
PROFILE_BITS: 8000000000030002
BLOCK 1: 1.LOCKED (MCC+MNC): 26202F
BLOCK 2: 1.LOCKED (MCC+MNC): F401F411F421F431F441F451F461F471F481F491
BLOCK 3: 1.LOCKED (MCC+MNC): F402F412F422F432F442F452F462F472F482F492F502F512F5 22F532F542F562F572F582F592F602F612F622F632F642F652 F662F672F682F692F702F712F722F732F742F752F762F772F7 82F792F802F812F822F832F842F852F862F872F882F892
BLOCK 4: 1.LOCKED (MCC+MNC): F153F163F173F183F193F303F313F323F333F343F353F363F3 73F383F393F503F513F523F533F543F563F573F583F593F603 F613F623F633F643F653F663F673F683F693F703F713F723F7 33F743F753F763F773F783F793F803F813F823F833F843F853 F863F873F883F893
BLOCK 5: 1.LOCKED (MCC+MNC): F104F114F124F134F144F214F224F234F244F254F264F274F2 84F294F304F314F324F334F344F354F364F374F384F394F404 F414F424F434F444F454F464F474F484F494F504F514F524F5 34F544F564F574F584F594F604F614F624F634F644F704F714 F724F734F744F754F764F774F784F794F804F814F824F834F8 44F954F964F974F984F994
BLOCK 6: 1.LOCKED (MCC+MNC): F105F115F125F135F145F205F215F225F235F245F305F315F3 25F335F345F355F365F375F385F395F405F415F425F435F445 F455F465F475F485F495F505F515F525F535F545F565F575F5 85F595F605F615F625F635F645F655F665F675F685F695F705 F715F725F735F745F755F765F775F785F795
BLOCK 7: 1.LOCKED (MCC+MNC): F906F916F926F936F946F956F966F976F986F996
PhoneType:RH-122
SwVersion: V 03.70 14-04-09 RH-122 (c) Nokia
MCU file: rh122_003.700
Trying to find patch position ...OK, case id: 3
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 0035A486:2984DA60
Area [01000000-0101FFFF] erased in 0.735 s
Area [01160000-0117FFFF] erased in 0.719 s
Programming ...
Programming completed.
Updating SIMLOCK ...Error 0x14
Area [01000000-0101FFFF] erased in 0.719 s
Area [01160000-0117FFFF] erased in 0.687 s
Programming ...
Old 02-10-2010, 13:22   #2 (permalink)
Member: 1216493
Sonork: 100.1590644
Thanks Meter: 1,355
Hey Man Open Your Eyes 1661 Not Supported Yet Any Device
Old 02-10-2010, 13:38   #3 (permalink)
Member: 609820
Thanks Meter: 6
NOKIA 1661-2 RH-122 REPAIRED GOOD
http://forum.gsmhosting.com/vbb/show...6&postcount=28
Old 02-10-2010, 13:48   #4 (permalink)
Member: 48245
Thanks Meter: 27
Originally Posted by .:MuRaT YeLeR:. View Post
no body does unlock on 1661 m8 !
The Following User Says Thank You to fredellioty For This Useful Post:
Old 02-10-2010, 13:49   #5 (permalink)
shahinahmed007's Avatar
Member: 672312
Sonork: 100.1589313
Thanks Meter: 876
repair means,flashing ok but not unlock. currently unlock not support by any tool
Old 02-10-2010, 14:08   #6 (permalink)
Member: 609820
Thanks Meter: 6
hmm sorry:S
does not resort to wait another
Old 02-10-2010, 19:18   #7 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
not possible unlock yet by anyother so wait for update by all tools
MXkey nokia 1661 unlock problem merkeza MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-20-2010 20:07
1661 unlock problem billa2008 Nokia Hardware & Hardware Repair 3 10-02-2009 15:47
6310i ver 5.22 unlock problem ... pls help ... alianu Nokia Digital Core Technology 4 ( DCT-4 ) 3 06-17-2003 20:55
GD 55 Unlock Problem - PLS Help Synchro Panasonic 0 05-14-2003 07:25
Geo@i mt345 unlock problems....pls help PTR999 Mitsubishi 0 10-14-2002 09:56
Page generated in 0.60226 seconds with 9 queries
