05-26-2010, 10:28 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | 1661imei prooblem SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 Flash Imei: 01188500219186 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 0 Ppm Id: UC Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 |
05-26-2010, 10:35 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INSIDE THIS FLAG
Member: 660737 Status: Offline Thanks Meter: 105 | Quote:
05-26-2010, 10:37 | #3 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Quote:
05-26-2010, 10:46 | #5 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | log rebuild imei : Easy Imei restore for DCT4 phones started. ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 Flash Imei: 01188500219186 Invalid imei checksum ! Looking for backup for this phone ... Backup found, restoring to the phone ... ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! !!! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UC Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 |
05-26-2010, 11:49 | #10 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Here is your rpl keep working. don't forget to press thanks. |
The Following User Says Thank You to >>PakFones<< For This Useful Post: |
05-26-2010, 11:56 | #11 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | lofo online log not work ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 ASIC type: 11 UEM Imei: 01188500219186 SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\01188500219186.RP L" ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00247FB7A3BDA66 Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UC Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
05-26-2010, 11:57 | #12 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | Phone Type: RH-121 SW Version: V 03.70 04-14-09 RH-121 (c) Nokia Imei plain: ??????????????-? Product Code: 0576976 Cellular System: GSM ASIC ID: 0x2293, type: 11 Ppm Id: UC Language Pack: - not available. Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000030000 SIMLOCK_DATA corrupted! |
05-26-2010, 12:16 | #15 (permalink) |
Member: 195225 Status: Offline Thanks Meter: 94 | Programming FLASH Imei ... FLASH programmed successfully. warning: For UEM write, VBAT needs to be atleast: 5.2V Programming UEM Imei (OTP) ...failed Phone Type: RH-121 |
6233 network prooblem | boniface wamuny | Nokia Hardware & Hardware Repair | 14 | 10-15-2007 06:26 |
6230 prooblem | segun01 | Nokia Hardware & Hardware Repair | 1 | 07-17-2007 10:51 |
K508i flashing prooblem | paklink | FuriouS II | 11 | 06-28-2005 18:34 |
