01-10-2010, 08:26 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | 1680c simlock data corrupted hi....... i have a problem flashing 1680c... the old version of the phone is 5.61...and i flash it to a same version but i get an error..... it says simlock data corrupted..... now the phone is CS......i try to unlock it but when i do patch unlocking the phone is dead so i undo it...... what shud i do?........ here is the info logs........ Code: Phone Type: RM-394 (Nokia 1680c-2) SW Version: V 05.61 18-04-08 RM-394 (c) Nokia Imei plain: 35678********-9 Imei OTP: 35678******** Product Code: 0566422 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: EL Language Pack: - not available. Imei net: 35678******** Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! |
01-10-2010, 08:35 | #3 (permalink) |
No Life Poster Join Date: Mar 2009 Location: Republic of Mindanao
Member: 990900 Status: Offline Thanks Meter: 540 | simple triks is just unlock the phone again after you flash then your problem was solve |
The Following User Says Thank You to Code:L.A 22 For This Useful Post: |
01-10-2010, 09:03 | #5 (permalink) |
Member: 557796 Status: Offline Thanks Meter: 187 | problem solved Code: Imei net: 35678********* Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555015555 SIMLOCK_DATA corrupted! PhoneType:RM-394 SwVersion: V 06.82 26-09-08 RM-394 (c) Nokia MCU file: rm394__06.82.mcusw Trying to find patch position ...OK ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000D07E1:3B8ADA60 Area [01000000-0101FFFF] erased in 0.610 s Area [016A0000-016BFFFF] erased in 0.625 s Area [013C0000-013DFFFF] erased in 0.562 s Area [01440000-0145FFFF] erased in 0.485 s Area [01C20000-01C3FFFF] erased in 0.672 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 1.328 s Reading Simlock info ... Imei net: 35678********* Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following 3 Users Say Thank You to =Deftones= For This Useful Post: |
5220 simlock data corrupt , what to do ? | gsmsikar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 07-03-2009 05:19 |
N70 Simlock data corrupted | silhouette | Nokia Base Band 5 ( BB-5 ) | 20 | 06-17-2009 18:53 |
N80 Simlock Data Corrupted | mtony969 | Nokia Base Band 5 ( BB-5 ) | 0 | 10-05-2007 10:50 |
