09-05-2010, 14:12 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | 2 bUGS!!!! proof 001ce3167f: 001CE3167F - Nokia Flash/Repair v2.34B Box: CR V 1.002 256 Code: NK V 2.001 1052 SN: 001CE3167F Nokia Unlimited: 5050 times started SonyEricsson Trial: 0 left, each max 15min ============= Set Flash mode for info ============= Boot... Trying boot BB5 phone... rap3gv3_2nd.fg RAP3Gv3_algo.fg helen3_2nd.fg h3_sam_nand_xsr.fg BOOT OK... Phone Type: BB5 ------------------- SYSTEM ID Response: 12 blocks ------------- SYSTEM_ASIC_ID( APE ): 17100708 ASIC_MODE_ID( APE ): 00 PUBLIC_ID( APE ): F71435F614A59D67CA242A08103689CAB833AFA8 ROOT_KEY_HASH( APE ): 49A97E826B93BA20B7ED0B082475C00500000000 ROM_ID( APE ): 1DFD66132C872FD4 SYSTEM_ASIC_ID( RAP ): 000000010000022600010006010C192101003000 EM_ASIC_ID( RAP ): 00000295 EM_ASIC_ID( RAP ): 00000B22 PUBLIC_ID( RAP ): 1C200118A15F4E50CD8FDD6B109CF60D6DB46BDC ASIC_MODE_ID( RAP ): 00 ROOT_KEY_HASH( RAP ): BAF3A9C3DBFA8454937DB77F2B8852B1 ROM_ID( RAP ): 273F6D55DFAAF68F --------------- Device ID Response: 3 blocks ------------- Storage Device: Owner Asic: RAP NOR Index: 0 Flash: Samsung, 00EC 22E8 0000 6921 Storage Device Contents: Owner Asic: RAP 000000000000000000000000000000000000 ============= Set FBus mode for info ============= VBat is 3.91V Vpp pin has 0.09V, Not Connected Pins: Mbus 1, Box Tx 1, Box Rx 1, Bsi 0 Phone is in: Local mode Scanning files, please wait... Done WARNING: THE VERSION YOU SELECTED: 4.0839.42.0.1 is NOT the highest installed!!! the highest available is: 4.0850.43 Mcu N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx Ppm N73_rofx_4.0839.42.0.1_PRD.V08 Content N73_userarea_4.0839.42.0.1.U01 Model: RM-133 (N73-1) V 05wk47v61.1/09-07-08/RM-133 (c) Nokia. IMEI: 358973017603669 ERROR: Unable to open file d:\Products\RM-133\N73_rofx_4.0839.42.0.1_PRD.V08 Terminating flash procedure mt box can not open the file, because the file was used by mx key!!! "file still open" another bug is i can not flash n73!!! full working N73 , i try to flash it Version from phone: 05wk47v61.1 Version from file: 4.0839.42.0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: F71435F614A59D67CA242A08103689CAB833AFA8 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1C200118A15F4E50CD8FDD6B109CF60D6DB46BDC ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0xB8 bytes). Reading RAP CCC (0x0 bytes). Reading RAP HWC (0x0 bytes). Reading APE NPC (0x0 bytes). Reading APE VARIANT (0x0 bytes). Reading APE CCC (0x0 bytes). Reading APE HWC (0x0 bytes). Flash Imei: 35897301760366 NPC_DATA saved OK VARIANT_DATA saved OK SUPERDONGLE_KEY_DATA saved OK CMLA_KEY_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35897301760366_BA CK.rpl" Processing file: N73_4.0839.42.0.1_western_C00_PRD_cc.fpsx as MCU [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 46.93 MB Supported RAP Ids: 0103192101003000, 010C192101003000 Supported APE Ids: 17100708 APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: F71435F614A59D67CA242A08103689CAB833AFA8 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1C200118A15F4E50CD8FDD6B109CF60D6DB46BDC ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 loader not responding (0910000000B172) Flashing terminated with error(s) in 1 min 36.360 s RX Buffer: 0910000000B172 but in mt box: |
09-05-2010, 14:18 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: In The World
Member: 1294926 Status: Offline Sonork: 100.1608183 Thanks Meter: 126 | this is mxkey section not mtbox. if u have any probleme about mxkey post it here with it's log. if u want to make publicity there are many other way to do it. no regard. |
09-05-2010, 21:47 | #4 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | I think in this post no problem is seen,a member just want to show here a minor bug present in the mxkey. Hope mxkey team solved this issue in next update. Br. Vijendra Saini. |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
NOKIA lock 2 provider list needed | ondenuove | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-15-2011 16:45 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
