05-10-2012, 14:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: PAKISTAN
Member: 303790 Status: Offline Thanks Meter: 290 | 200 nokia error during flash Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000026C Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E98EAA7 Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm761__10.61.mcusw Downloading item CODE:rm761__10.61.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.375 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.344 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.500 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 33.203 s Checksum mismatch: Phone calculated 0xB25B, software calculated 0x9ED2 Task failed at (08000012)!!! Last RX buffer: 01 00 B2 5B 41 00 00 00 82 89 00 00 01 00 28 23 00 00 00 00 00 04 00 00 01 00 00 00 00 00 00 04 00 02 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |
05-10-2012, 15:57 | #2 (permalink) |
No Life Poster Join Date: May 2011 Location: KPK Mardan Age: 36
Member: 1582572 Status: Offline Sonork: 100.1609641 Thanks Meter: 573 | 100%%%% ok MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) Battery voltage: 3720 mV Warning battery voltage is less, phone might not detected after flash ! Waiting for USB device removal ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35194405375382 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK LOCK120_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35194405375382_ back.RPL" Processing file: rm761__10.60.mcusw Downloading item CODE:rm761__10.60.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.422 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.421 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.641 s Erasing area 0x40280000-0x41A7FFFE ...OK Programming completed in 29.515 s Checksum verified (0xA72F) Processing file: rm761__10.60.ppm_ma4 Downloading item CUSTackage_ma4.ppm_ebl_psi.fls, num block: 1, size: 5.06 MB Erasing area 0x41A80000-0x41F8E236 ...OK Programming completed in 6.297 s Checksum verified (0xED79) Processing file: rm761__10.60.image_ma4_059J4X2_002 Downloading item CUSTackage_ma4_059J4X2.image.fls, num block: 1, size: 9.75 MB Erasing area 0x421C0000-0x43E1FFFE ...OK Programming completed in 12.218 s Checksum verified (0x42E1) Total time for flashing process(boot+erase+write) was 4 min 51.906 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 2DE9ED78 Verifying communication to device OK. Phone type: RM-761 (Nokia 200) SW version: V 10.60 20-01-12 RM-761 (c) Nokia Imei plain: 35194405375382-2 Product code: 059J4L0 Battery voltage: 3705 mV, current: 102 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: MA4 Language Pack: - not available. Camera config: 06150123008027, ver: Imei net: 35194405375382 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
05-10-2012, 16:39 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
br, | |
05-11-2012, 03:10 | #4 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | @X-TRA Battery Low problem, use fully charge battery http://forum.gsmhosting.com/vbb/f550...error-1471416/ |
