Old 11-16-2009, 13:21   #1 (permalink)
Registered User
Member: 714467
Sonork: 100.1641520
Thanks Meter: 46
2300 rpl ????
haii have one 2300 imei is ????????????????4.and i flash withmx-key and right rpl with thw support of mx keyand its show every thing finebut set is turn off within 30 sec.wht is the reson?guide me plz there is the log ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164Performing Flash Authentication ...OKUEM ID: 00998E79:2984DA60ASIC type: 2UEM Imei: 30431500409321Connecting to server ...OK, Login ...Hello C080007E, you have 990 credits left.RPL saved to "C:\mobileEx\3.2\data\backup\RPL\30431500409321.RP L" ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164FlashID0: 0020 88DE [ST 58MR016C,8 Mbits] page size: 64 K type: NOR area: 01000000-010FFFFFFlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C20 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164Performing Flash Authentication ...OKUEM ID: 00998E79:2984DA60Programming FLASH Imei ...FLASH programmed successfully. Phone Type: RM-4 SW Version: V 8.11 19-06-06 RM-4 (c) NMP 2300 Imei plain: 30431500409321-2Product Code: 0513366Cellular System: GSMASIC ID: 0x1201, type: 2Ppm Id: EFLanguage Pack:English,Latvian,Russian
2300 rpl file habibkhalil Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-21-2009 08:23
Need RM-4 2300 rpl aswadsaad988920 Nokia Hardware & Hardware Repair 1 03-08-2007 08:48
2300-rpl zakirn Griffin 6 11-14-2006 17:03
nokia 2300 rpl REPAIR68 UFS2 + UFS3-Tornadoflasher 1 01-25-2006 21:29
griffin 2300 rpl files fatih Griffin 2 05-28-2004 01:40
Page generated in 0.11631 seconds with 10 queries
