07-08-2010, 10:48 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: kolkata
Member: 772386 Status: Offline Thanks Meter: 157 | 2310 automaticly insert sim after few minutes i post the bus check log device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D91F55:2984DA60 ASIC type: 2 UEM Imei: 35553201120656 Flash Imei: 35553201120656 MasterCode: 1263314720 RPL saved to "C:\mobileEx\3.4\data\backup\35553201120656_BACK.r pl" Phone Type: RM-189 SW Version: V 6.52 11-12-07 RM-189 (c) NMP Imei plain: 35553201120656-5 Product Code: 0541719 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: - not available. Imei net: 35553201120656 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN help me plz its very urzent |
07-08-2010, 11:53 | #3 (permalink) |
Member: 772386 Status: Offline Thanks Meter: 157 | device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_st_i.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x4C58 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 00D91F55:2984DA60 ASIC type: 2 UEM Imei: 35553201120656 Flash Imei: 35553201120656 MasterCode: 1263314720 RPL saved to "C:\mobileEx\3.4\data\backup\35553201120656_BA CK.r pl" Phone Type: RM-189 SW Version: V 6.52 11-12-07 RM-189 (c) NMP Imei plain: 35553201120656-5 Product Code: 0541719 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: MG Language Pack: - not available. Imei net: 35553201120656 Version: Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 8000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN help me plz its very urzent red line version is blank this is problem or not? |
07-08-2010, 12:50 | #4 (permalink) |
No Life Poster Join Date: Nov 2007 Location: United State Of Islam Age: 34
Member: 624551 Status: Offline Sonork: 100.1584837 Thanks Meter: 737 | first clean bettery terminal, second change bettery, if still same then click this link... RapidShare: 1-CLICK Web hosting - Easy Filehosting note: some time removing of component the phone become local or test mode then change it from another circuit.......... with best wishes... |
07-08-2010, 19:11 | #6 (permalink) | |
Member: 772386 Status: Offline Thanks Meter: 157 | Quote:
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
