Old 04-08-2011, 10:54   #1 (permalink)
Member: 713374
Sonork: 100.1597179
Thanks Meter: 223
2310 rpl error (ANSWERED)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 001485D2:2984DA60
ASIC type: 2
UEM Imei: 24154501337659
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.6
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\24154501337659.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RM-189
SW Version: V 6.52 11-12-07 RM-189 (c) NMP
Imei plain: ??????????????-?
Product Code: 0534605
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Counter: 0/3, 0/10
CONFIG_DATA: 2EDF7E52684B32B7
PROFILE_BITS: 3F5B6DAD6C013F0B
The Following User Says Thank You to xim360 For This Useful Post:
Old 04-08-2011, 10:58   #2 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
go to imei tab then imei change tab
fill the new imei
then click on change imei
Old 04-09-2011, 03:39   #3 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
imei patch is intended to modify data1, not to repair it.
2310 is is categorized as DCT4+, please select ASIC11 when doing online logger.
i saw weird uem imei "24154501337659", possible also uem is damaged.
Old 04-10-2011, 07:23   #4 (permalink)
Member: 262993
Sonork: 1617996
Thanks Meter: 15
ASIC type: 2
Phone Type: RM-189
Ppm Id: IA
Language Pack:
Counter: 0/3, 0/10
Brother 1st flash phone , then give rpl again
then post reply
Old 04-10-2011, 07:36   #5 (permalink)
BIGUNLOCKSERVER's Avatar
Member: 1542932
Sonork: 100.1621006
Thanks Meter: 53
see this in your log.
no solution in software.
you have to change uem then install new rpl. u can use old uem from nokia 1200.
tested meny times
post replay
Old 05-09-2011, 12:28   #6 (permalink)
Member: 836059
okyyyyyyyyyyyyyyyyyyyyyyyy
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
Avoid 3 times error code in Nokia 6185 X-plot Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-08-2000 20:24
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Page generated in 0.19857 seconds with 10 queries
