Old 02-18-2010, 07:06   #1 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Exclamation 2330c camera on standby how to solve
hello how to solve camera on standby 2330c mx key team
Old 02-18-2010, 07:07   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,604
searh before post u can find 100 way to fix this problem with mx key
Old 02-18-2010, 07:08   #3 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
i search and i try to do that error camera patch accrued mx key not solve
Old 02-18-2010, 07:28   #4 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
RPL saved to "C:\mobileEx\3.3\data\backup\35831603836176_126647 7190_BACK.RPL"
BT MAC repair ...Ok
Reseting LCD setting ...Ok
File Saved to "F:\Lee hard drive\all file d transfer\ALL FILES HERE\saras soft box\dct4\ALL PM\GR0103D1012601022E05_XXXXXX.dcc"
Camera Configuration file write failed !
Camera test failed.
Camera test failed.
Camera test failed.
Testing Camera IF ...passed.
Camera test failed.
Camera test failed.
File Saved to "F:\ALL BOX FILES & UPDATES\mx key\camera stand by solution\camera stand by solution\GR0103D1012601022E05_XXXXXX.dcc"
Old 02-18-2010, 07:35   #5 (permalink)
Member: 736901
Thanks Meter: 11
BT MAC repair ...Ok
Camera test failed.
Camera test failed.
Camera test failed.
Camera test failed.
Camera test failed.
try this boss meybe can solve ur prblm......
http://www.sendspace.com/file/v9ujhu
Old 02-18-2010, 07:38   #6 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
inside of mx key have a problem in cheap bugs are so many pleas fixed that
Old 02-18-2010, 07:40   #7 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
i try that but field to initialized camera so that's why i report this bugs
Old 02-18-2010, 07:41   #8 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,265
[Share here] Dynamic Camera Configuration / CAMERA ON STANDBY PATCH
Old 02-18-2010, 07:44   #9 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
yes i know that i all ready see that but even i try i try ufs and jap box inter pace .same camera error
Old 02-18-2010, 08:36   #10 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
mx key is fake
cannot fixed
Old 02-18-2010, 08:37   #11 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
Using device: J.A.F, FW ver: 01.B2
Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2600 [Samsung ] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
Performing Flash Authentication ...OK
UEM ID: 00952E7C:3B8ADA60
ASIC type: 11
UEM Imei: 35831603836176
Flash Imei: 35831603836176
MasterCode: 7074117070
RPL saved to "C:\mobileEx\3.3\data\backup\35831603836176_126648 1127_BACK.rpl"
Phone Type: RM-512 (Nokia 2330c-2)
SW Version: V 08.20 30-06-09 RM-512 (c) Nokia
Imei plain: 35831603836176-0
Imei OTP: 35831603836176
Product Code: 0572699
Cellular System: GSM
ASIC ID: 0x3168, type: 11
Ppm Id: S
Language Pack:
- not available.
Imei net: 35831603836176
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
RPL saved to "C:\mobileEx\3.3\data\backup\35831603836176_126648 1134_BACK.RPL"
Camera test failed.
Writing PM from Node ...
S
ection: 1
- Key: 0, size 120 bytes written.
- Key: 2, size 90 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 90 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 2 bytes written.
Section: 2
- Key: 0, size 440 bytes written.
Section: 4
- Key: 1, size 180 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 16, size 4 bytes written.
- Key: 17 skipped
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
- Key: 28, size 2 bytes written.
Section: 7
- Key: 0, size 4 bytes written.
- Key: 1, size 32 bytes written.
- Key: 2, size 4 bytes written.
Section: 8
- Key: 0, size 2 bytes written.
- Key: 1, size 16 bytes written.
- Key: 2, size 16 bytes written.
- Key: 3, size 128 bytes written.
- Key: 4, size 128 bytes written.
- Key: 7, size 4 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 8 bytes written.
- Key: 10, size 24 bytes written.
Section: 11
- Key: 1, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 2 bytes written.
- Key: 7, size 1 bytes written.
- Key: 8, size 1 bytes written.
- Key: 9, size 1 bytes written.
- Key: 10, size 1 bytes written.
- Key: 11, size 1 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 2 bytes written.
- Key: 15, size 2 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 2 bytes written.
- Key: 18, size 16 bytes written.
- Key: 19, size 32 bytes written.
- Key: 20, size 32 bytes written.
- Key: 21, size 2 bytes written.
- Key: 22, size 2 bytes written.
- Key: 23, size 2 bytes written.
- Key: 24, size 2 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 29, size 2 bytes written.
- Key: 30, size 2 bytes written.
- Key: 31, size 2 bytes written.
- Key: 32, size 2 bytes written.
- Key: 33, size 2 bytes written.
- Key: 34, size 2 bytes written.
- Key: 35, size 2 bytes written.
- Key: 36, size 2 bytes written.
- Key: 37, size 2 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 2 bytes written.
- Key: 44, size 2 bytes written.
- Key: 45, size 2 bytes written.
- Key: 46, size 2 bytes written.
- Key: 47, size 2 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 2 bytes written.
- Key: 51, size 2 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 2 bytes written.
- Key: 54, size 2 bytes written.
- Key: 55, size 2 bytes written.
- Key: 56, size 2 bytes written.
- Key: 57, size 2 bytes written.
- Key: 58, size 2 bytes written.
- Key: 59, size 2 bytes written.
- Key: 60, size 2 bytes written.
- Key: 61, size 2 bytes written.
- Key: 62, size 2 bytes written.
- Key: 63, size 2 bytes written.
- Key: 64, size 2 bytes written.
- Key: 65, size 2 bytes written.
- Key: 66, size 4 bytes written.
- Key: 67, size 1 bytes written.
- Key: 68, size 4 bytes written.
- Key: 69, size 4 bytes written.
- Key: 70, size 4 bytes written.
- Key: 71, size 4 bytes written.
- Key: 72, size 16 bytes written.
- Key: 73, size 4 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 13 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 13
- Key: 0, size 1 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 1 bytes written.
- Key: 3, size 2 bytes written.
- Key: 5, size 1 bytes written.
- Key: 6, size 1 bytes written.
- Key: 8, size 2 bytes written.
- Key: 11, size 48 bytes written.
- Key: 12, size 4 bytes written.
- Key: 14, size 1 bytes written.
- Key: 15, size 886 bytes written.
- Key: 17, size 1 bytes written.
- Key: 18, size 1 bytes written.
- Key: 19, size 8 bytes written.
- Key: 20, size 1 bytes written.
- Key: 21, size 1 bytes written.
- Key: 22, size 1 bytes written.
- Key: 23, size 1 bytes written.
- Key: 24, size 1 bytes written.
- Key: 26, size 1 bytes written.
- Key: 27, size 1 bytes written.
- Key: 28, size 1 bytes written.
- Key: 29, size 1 bytes written.
- Key: 30, size 1 bytes written.
- Key: 31, size 1 bytes written.
- Key: 32, size 1 bytes written.
- Key: 33, size 1 bytes written.
- Key: 34, size 1 bytes written.
- Key: 35, size 1 bytes written.
- Key: 36, size 1 bytes written.
- Key: 37, size 4 bytes written.
- Key: 38, size 1 bytes written.
- Key: 39, size 1 bytes written.
- Key: 40, size 1 bytes written.
- Key: 41, size 1 bytes written.
- Key: 42, size 4 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 1 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 4 bytes written.
- Key: 47, size 1 bytes written.
- Key: 48, size 4 bytes written.
- Key: 49, size 1 bytes written.
- Key: 50, size 1 bytes written.
- Key: 51, size 1 bytes written.
- Key: 53, size 4 bytes written.
- Key: 54, size 4 bytes written.
- Key: 55, size 1 bytes written.
- Key: 56, size 1 bytes written.
- Key: 57, size 1 bytes written.
- Key: 59, size 1 bytes written.
- Key: 60, size 4 bytes written.
- Key: 61, size 4 bytes written.
- Key: 62, size 1 bytes written.
- Key: 63, size 4 bytes written.
- Key: 64, size 4 bytes written.
- Key: 65, size 1 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 1 bytes written.
- Key: 69, size 1 bytes written.
- Key: 70, size 1 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 1 bytes written.
- Key: 74, size 4 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 1 bytes written.
- Key: 79, size 1 bytes written.
- Key: 80, size 1 bytes written.
- Key: 81, size 1 bytes written.
- Key: 82, size 1 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 1 bytes written.
- Key: 85, size 4 bytes written.
- Key: 86, size 4 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 1 bytes written.
- Key: 89, size 4 bytes written.
- Key: 90, size 4 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 1 bytes written.
- Key: 93, size 4 bytes written.
- Key: 94, size 4 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 1 bytes written.
- Key: 97, size 4 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 1 bytes written.
- Key: 103, size 4 bytes written.
- Key: 104, size 4 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 4 bytes written.
- Key: 110, size 4 bytes written.
- Key: 111, size 4 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 4 bytes written.
- Key: 114, size 4 bytes written.
- Key: 115, size 1 bytes written.
- Key: 116, size 1 bytes written.
- Key: 117, size 1 bytes written.
- Key: 118, size 4 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 1 bytes written.
- Key: 121, size 1 bytes written.
- Key: 122, size 1 bytes written.
- Key: 123, size 8 bytes written.
- Key: 124, size 1 bytes written.
- Key: 125, size 1 bytes written.
- Key: 126, size 1 bytes written.
- Key: 127, size 1 bytes written.
- Key: 128, size 1 bytes written.
- Key: 129, size 4 bytes written.
- Key: 130, size 4 bytes written.
- Key: 131, size 1 bytes written.
- Key: 132, size 1 bytes written.
- Key: 133, size 2 bytes written.
- Key: 134, size 1 bytes written.
- Key: 135, size 2 bytes written.
- Key: 136, size 1 bytes written.
- Key: 137, size 1 bytes written.
- Key: 138, size 4 bytes written.
- Key: 139, size 4 bytes written.
- Key: 140, size 1 bytes written.
- Key: 141, size 1 bytes written.
- Key: 142, size 1 bytes written.
- Key: 143, size 1 bytes written.
- Key: 144, size 4 bytes written.
- Key: 145, size 8 bytes written.
- Key: 146, size 4 bytes written.
- Key: 147, size 4 bytes written.
- Key: 148, size 1 bytes written.
- Key: 149, size 1 bytes written.
- Key: 150, size 1 bytes written.
- Key: 151, size 1 bytes written.
- Key: 152, size 1 bytes written.
- Key: 153, size 1 bytes written.
- Key: 154, size 1 bytes written.
- Key: 155, size 1 bytes written.
- Key: 156, size 1 bytes written.
- Key: 157, size 1 bytes written.
- Key: 158, size 1 bytes written.
- Key: 159, size 2 bytes written.
- Key: 160, size 2 bytes written.
- Key: 161, size 1 bytes written.
- Key: 162, size 1 bytes written.
- Key: 163, size 1 bytes written.
- Key: 164, size 1 bytes written.
- Key: 165, size 1 bytes written.
- Key: 166, size 1 bytes written.
Section: 42
- Key: 1, size 12 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 40 bytes written.
- Key: 8, size 40 bytes written.
- Key: 9, size 40 bytes written.
- Key: 10, size 40 bytes written.
- Key: 11, size 40 bytes written.
- Key: 12, size 40 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
Section: 44
Section: 46
- Key: 0, size 8 bytes written.
Section: 50
Section: 54
Section: 59
- Key: 0, size 33 bytes written.
Section: 65
- Key: 0, size 11 bytes written.
- Key: 1, size 11 bytes written.
- Key: 2, size 11 bytes written.
- Key: 3, size 11 bytes written.
- Key: 4, size 11 bytes written.
Section: 66
- Key: 0, size 401 bytes written.
- Key: 1, size 240 bytes written.
- Key: 2, size 240 bytes written.
- Key: 3, size 1 bytes written.
- Key: 5, size 240 bytes written.
- Key: 6, size 4 bytes written.
- Key: 8, size 4 bytes written.
- Key: 9, size 4 bytes written.
- Key: 10, size 120 bytes written.
- Key: 11, size 240 bytes written.
- Key: 53, size 1 bytes written.
- Key: 65, size 4 bytes written.
- Key: 75, size 4 bytes written.
- Key: 76, size 4 bytes written.
- Key: 77, size 4 bytes written.
- Key: 78, size 4 bytes written.
- Key: 79, size 4 bytes written.
- Key: 81, size 4 bytes written.
- Key: 82, size 4 bytes written.
- Key: 83, size 4 bytes written.
- Key: 85, size 80 bytes written.
- Key: 86, size 6400 bytes written.
- Key: 87, size 400 bytes written.
- Key: 88, size 60 bytes written.
- Key: 96 skipped, frame length too long
- Key: 100, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 104, size 3 bytes written.
- Key: 105, size 3 bytes written.
- Key: 106, size 3 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 160 bytes written.
- Key: 111, size 40 bytes written.
- Key: 113, size 1 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 1, size 20 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 132 bytes written.
- Key: 26, size 12 bytes written.
Section: 116
- Key: 15, size 40 bytes written.
- Key: 16, size 40 bytes written.
Section: 117
- Key: 1, size 3 bytes written.
- Key: 2, size 6 bytes written.
- Key: 4, size 9 bytes written.
- Key: 5, size 10 bytes written.
- Key: 13, size 3 bytes written.
- Key: 14, size 3 bytes written.
- 120 skipped
Section: 163
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
- Key: 0, size 40 bytes written.
Section: 217
- Key: 0, size 32 bytes written.
Section: 218
Section: 232
- Key: 0, size 20 bytes written.
Section: 238
- Key: 1, size 1 bytes written.
Section: 250
- Key: 1, size 1988 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 674 bytes written.
Section: 301
Section: 308
Section: 322
Section: 334
Section: 354
- Key: 0, size 15 bytes written.
Section: 355
- Key: 1, size 1323 bytes written.
Section: 362
Warning: failed to write 362 - 0 (255 bytes)
Warning: failed to write 362 - 1 (510 bytes)
Section: 364
Section: 365
Completed in 1 min 16.343 s
Old 02-18-2010, 09:13   #12 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
mx key moderator how to solve 2330c not supported see this
Old 02-18-2010, 09:55   #13 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
problem solve by j.a.p
Old 02-25-2011, 02:23   #14 (permalink)
Member: 592458
Thanks Meter: 2
numpang nyimak boss...
Old 02-25-2011, 04:06   #15 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 258
What is j.a.p????...................................
bb5 camera on standby solved easy way...... soukot.bd Nokia Base Band 5 ( BB-5 ) 7 03-30-2010 18:42
amoi skype wps1 still on logo how to solve mr blang Master Software Z3X-Team Products 2 03-06-2010 14:28
China phone problems Like this:input power on pwd How to solved FullFLASHgSMPH SpiderMan 0 10-17-2009 11:23
bb 7290 error 507 on display how to solve? FMC_GSM BlackBerry (RIM) 2 08-14-2008 04:28
Page generated in 0.63110 seconds with 8 queries
