2330c contact service Imei net: 35831603509135 Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Calculating SIMLOCK RPL using security server ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.5 Rpl backup saved to "C:\mobileEx\3.4\data\backup\RM-512_35831603509135_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35831603509135 Version: SIMLOCK SERVER Provider: GSM Test Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPE i flached and unlocked but still contact service |
try to erase phone than flashing again and write good pm than unlock |
i erased and flached and write full pm than unlock but still contact service this selftest Phone Type: RM-512 SW version: V 09.85 11-03-10 RM-512 (c) Nokia ID Test name Startup Result 46 UEM_CBUS_IF Y PASSED(00) 1 AUX_DA_LOOP Y PASSED(00) 3 EAR_DATA_LOOP Y PASSED(00) 17 TX_IDP_LOOP N !NOT EXECUTED(03) 18 TX_IQ_DP_LOOP N !NOT EXECUTED(03) 12 SIM_CLK_LOOP Y !NO SIGNAL(06) 13 SIM_IO_CTRL_LOOP Y !NO SIGNAL(06) 8 MBUS_RX_TX_LOOP Y PASSED(00) 20 BACKUP_BATT Y PASSED(00) 42 RADIO Y !FAILED(01) 39 WARRANTY N !NOT EXECUTED(03) 33 SIM_LOCK Y PASSED(00) 10 PPM_VALIDITY N PASSED(00) 7 KEYBOARD_STUCK N !NOT EXECUTED(03) 43 LCD N !NOT EXECUTED(03):( 41 FLASH_CHECKSUM N PASSED(00) 22 CAMERA_IF N !NOT EXECUTED(03) 54 EXT_RAM_DATA_BUS N !NOT EXECUTED(03) 55 EXT_RAM_ADDR_BUS N !NOT EXECUTED(03) 71 BT_WAKEUP N !NOT EXECUTED(03):( |
try to reheat upp or try to change.... |
Problem on hardware Change Sim ic |
Use Mx-key Brother Ur Problem Is Solved 1000000% Its tested For Me |
