02-02-2011, 05:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: ISLD
Member: 1489021 Status: Offline Sonork: 100.1620946 Thanks Meter: 831 | 2330c contact service (ANSWERED) Phone Type: RM-512 (Nokia 2330c-2) SW Version: V 09.85 11-03-10 RM-512 (c) Nokia Imei plain: 35831603208047-3 Imei OTP: 35831603208047 Product Code: 0572783 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: EJ Language Pack: - not available. Imei net: 35831603208047 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 5555555555555555 PROFILE_BITS: 5555555555035555 SIMLOCK_DATA corrupted! |
02-02-2011, 05:28 | #2 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Bangladesh
Member: 665514 Status: Offline Sonork: 100.1618806 Thanks Meter: 325 | Use Mx-key Brother Ur Problem Is Solved 1000000% Its tested For Me |
The Following User Says Thank You to amit_gsm For This Useful Post: |
04-11-2011, 10:28 | #4 (permalink) |
Junior Member Join Date: Jul 2006
Member: 321372 Status: Offline Thanks Meter: 2 | I have a nokia 2330 classic cell phone.The problem is when it is turned on, its display flashes/blinks in white color. I have tried doing flashing using MXKEY and JAF but they both give the error while in erasing phase...if I skip the erasing it gives error at MCUID...please help and give me the solution as soon as possible.anxiously waiting |
04-11-2011, 11:41 | #5 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
good luck bro br | |
04-11-2011, 11:42 | #6 (permalink) | |
can u post the flashing log please bro?? | |
04-11-2011, 11:53 | #8 (permalink) |
Member: 321372 Status: Offline Thanks Meter: 2 | here is the ecomplete error log bro: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0000 0001 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0000 0001 0002 0003 0004 0005 0006 0007 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001639DA:3B8ADA60 ASIC type: 11 UEM Imei: 35524803682578 Processing MCU file: rm512__09.55.mcusw [DCT4,DCT4 ALGORITHM] size: 11.87 MB Supported Ids: 3160, 3161, 3162, 3164, 3166, 3168 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0000 0001 [unused/removed] FlashID1: 0000 0001 [unused/removed] ExtBUSC: 0000 0001 0002 0003 0004 0005 0006 0007 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 001639DA:3B8ADA60 Area [01000000-0101FFFF] erased in 0.078 s Area [01020000-01CFFFFF] erased in 4.938 s Flash programming ... Error while programming [14] at 0x01000000, Result: 0872 flashing terminated ! Flashing terminated with error(s) in 1 min 6.782 s RX Buffer: 0872 PS: When I try to start flashing it gives a message that "could not save RPL backup from phone" Please help bro |
Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-27-2012 11:00 |
unlock Service Provider Code for PrimeCo (USA) in 6185 Nokia Phone | X-plot | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-11-2000 03:43 |
gsm service provider | sidou | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-30-2000 11:09 |
FREE SP unlock service | timxy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-1999 16:05 |
NOKIA TECHNICAL SERVICE BOOK AND NOKIA SERVICING SIM CARD FOR SALE TRADE FOR 7110 | andrew bennett | Main Sales Section | 0 | 07-09-1999 10:41 |
