11-10-2009, 08:22 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Darwin Northern Teretory Age: 40
Member: 136173 Status: Offline Sonork: 108426:ind Thanks Meter: 97 | 2330c sucessfully unlocked 1: flash to this version ie 6.75 2. select asic 11 3. sp lock info update sp lock eurekka unlocked ...........test report below i will test al australian phones and post result Imei net: 3552***********304 Provider: Vodafone, Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 50503F PhoneType:RM-512 SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia MCU file: rm512__06.75.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 000D7BA7:3B8ADA60 Area [01000000-0101FFFF] erased in 0.984 s Area [01220000-0123FFFF] erased in 0.921 s Area [01440000-0145FFFF] erased in 0.860 s Area [014C0000-014DFFFF] erased in 0.797 s Area [01CE0000-01CFFFFF] erased in 0.828 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 24.781 s Reading Simlock info ... Imei net: 35524******17304 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following 10 Users Say Thank You to zipzap_kill For This Useful Post: |
11-11-2009, 11:50 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | I did one today. Full working with FULL SIGNAL ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0089 8981 [Intel NU48F256,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x5548 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00926CBB:3B8ADA60 Area [01000000-0101FFFF] erased in 0.719 s Area [01220000-0123FFFF] erased in 0.703 s Area [01440000-0145FFFF] erased in 0.782 s Area [014C0000-014DFFFF] erased in 0.735 s Area [01CE0000-01CFFFFF] erased in 0.656 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 1 min 27.172 s Reading Simlock info ... Imei net: 35524803276950 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-12-2009, 13:54 | #6 (permalink) |
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | |
The Following 3 Users Say Thank You to nasirahmed For This Useful Post: |
12-28-2009, 02:31 | #8 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Taguig CT Age: 42
Member: 488875 Status: Offline Sonork: 100.1626294 Thanks Meter: 1,129 | |
The Following User Says Thank You to bronce For This Useful Post: |
.::::: 2330c successfully unlock once again thanks GT ::::. | sairat | MT-BOX | 1 | 10-05-2009 22:39 |
2330c -patch unlock failed | modzek | MT-BOX | 0 | 10-02-2009 17:56 |
.::::: 2330c successfully unlock once again thanks GT ::::. | sairat | MT-BOX | 0 | 09-29-2009 16:01 |
2330c Not unlocked and logs gone. | GSM-STUDENT | MT-BOX | 5 | 09-05-2009 13:03 |
