05-25-2011, 14:40 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: punjab india
Member: 421487 Status: Offline Thanks Meter: 58 | 7210c only nokia logo and black screen Library version: 1.0.0.9113(26-12-2010), 1.0.0.15868(10-03-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 12B0010A44B5495001831115D3801C29E7325684 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Original Imei: 35934903670120 Original Product code: 0581686 Bluetooth ID: 20D6075007A9 Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35934903670120-7 Product Code: 0581686 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid [ during unlocking] Failed to read SP data Failed to read SP data Backup saved to "BB5_35934903670120_SIMLOCK.back" Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15868(10-03-2011) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[12B0010A44B5495001831115D3801C29E7325684] ... Calculating NCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 #pw+ 019563309358685 +1 # #pw+ 990847723543662 +2 # #pw+ 774868217515631 +3 # #pw+ 009535017570184 +4 # #pw+ 788578244847315 +5 # #pw+ 766878060730084 +6 # #pw+ 917978151650331 +7 # Sending NCK code ... Trying NCK lock 7 ...Trying NCK lock 6 ...Trying NCK lock 5 ...Trying NCK lock 4 ...Trying NCK lock 3 ...Trying NCK lock 2 ...Trying NCK lock 1 ... Reading Simlock info ... Failed to read SP data [reparing sim lock]Failed to read SP data Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15868(10-03-2011) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[12B0010A44B5495001831115D3801C29E7325684] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.7 Completed in 3.015 s RPL saved to "D:\3.4\data\backup\BB5_RM-436_359349036701207_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data |
05-25-2011, 17:44 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
05-26-2011, 06:44 | #7 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | direct unlock sp lock Failed to read SP data Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9113(26-12-2010), 1.0.0.15868(10-03-2011) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[12B0010A44B5495001831115D3801C29E7325684] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Completed in 3.672 s RPL saved to "D:\3.4\data\backup\BB5_RM-436_359349036701207_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... Failed to read SP data |
05-26-2011, 10:41 | #8 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | 1- make backup RPL (especialy NPC data) backup imei will be created in D:\3.4\data\backup 2- in certificate reset tick NPC then reset selected. 3- after this write RPL software will ask you a file, so give your calculated simlock (BB5_RM-436_359349036701207_SIM.RPL) D:\3.4\data\backup\BB5_RM-436_359349036701207_SIM.RPL if write done then 4- restore your imei backup and all will be fine. hope this can help you. PS: your problem is how to write calculated simlock nothing more so dont be confused with other things good luck |
05-26-2011, 15:18 | #9 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | i trying that you write but same problem pl check Imei: 35934903670120 Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating PROD ...OK Updating BT ...OK CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 12B0010A44B5495001831115D3801C29E7325684 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Updating PRODUCTCODE (0581686)... OK Updating PSN (KFW232508)... OK Updating HWID (3005)... OK Updating SIMLOCK...error 0x14 Updating SUPERDONGLE_KEY ...OK Updating CMLA_KEY...OK Updating WMDRM_PD...OK Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35934903670120-7 Product Code: 0581686 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid Failed to read SP data |
05-26-2011, 15:35 | #10 (permalink) | |
Junior Member Join Date: Apr 2011 Location: india
Member: 1555845 Status: Offline Sonork: 100.1604818 Thanks Meter: 4 | Quote:
1st flash letest flash file 2st repair sd,sd auth 3st read pm,pm auth 4st write pm and <RF/BB YOUR SET OK I AM TESTED MANY TIME PLZ U CHEK AND POST AGAIN PLZ | |
05-26-2011, 16:06 | #11 (permalink) | |
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | Quote:
you have to change older simlock data on it with newer (calculated by server), also respect this order 1- reset NPC data 2- write calculated simlock by server (this file in your case D:\3.4\data\backup\BB5_RM-436_359349036701207_SIM.RPL) if write is ok the: 3- from your backup rpl you must delete all corrupted (older) simlock data, you can do this with any text editor program. 4- write back rpl | |
05-26-2011, 16:10 | #12 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: pakistan
Member: 601913 Status: Offline Sonork: 100.1597350 Thanks Meter: 658 | Quote:
06-07-2011, 09:27 | #14 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | some time things are easy to do with the respect of other people in the market if u are not able to handle 7210S dont think the box is not supportive or its ur fault make happen with some one else and give it back to customer and post the log here with readed PM and RPL which u calculate so the moderator of this forum able to have a look at that problem and be patient teams have to work really hard for the new upcoming models and sequences series. |
06-07-2011, 09:40 | #15 (permalink) |
Member: 421487 Status: Offline Thanks Meter: 58 | dear sir i will trying my best with mx key and ub sim lock repair [20 cadit ] but phone is still same in mx key 1st back up npc ,2nd erese flash ,3 full flash,4 recover cert ,5 restore npc ,6 sd repair,7 sd oth, 8write pe with server,9 repir sim lock but result is same pl give me step by step procees for this |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
