01-27-2010, 11:51 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: face horror Age: 37
Member: 826568 Status: Offline Sonork: 100.1580161 Thanks Meter: 44 | 2330c unlonk fail Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.LOCKED (MCC+MNC): 23433F BLOCK 2: 1.LOCKED (MCC+MNC): 23486F PhoneType:RM-512 SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia MCU file: rm512__06.75.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 BootLoader not responding, mostly RAM problem ! |
01-27-2010, 11:53 | #2 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Philippines
Member: 557796 Status: Offline Thanks Meter: 187 | what cable are u using sir?...... try easy cable for that unit......or try UFC cable...... then patch unlock it..... |
The Following User Says Thank You to =Deftones= For This Useful Post: |
01-27-2010, 14:08 | #6 (permalink) |
Crazy Poster Join Date: Feb 2006 Location: Pancevo,Vojvodina,Srbija Age: 38
Member: 230888 Status: Offline Thanks Meter: 7 | PhoneType:RM-512 SwVersion: V 08.20 30-06-09 RM-512 (c) Nokia MCU file: rm512__08.20.mcusw Trying to find patch position ...OK ASIC ID: 0x3168 [UPP_8M ver: 6.4] Missing flash update definition file ! Sorry, Unable to find bootloader for this AsicID ! What is my problem? |
01-27-2010, 14:27 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Rawalpindi, Pakistan
Member: 421117 Status: Offline Sonork: +92 346 5544377 (PHONE) Thanks Meter: 2,522 | Code: BootLoader not responding, mostly RAM problem ! Try to use older Version for the desired operation.You could install both new and older versions in same PC. Br, Umair |
The Following User Says Thank You to Umair Rashid For This Useful Post: |
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] | mariaperezkkk | Cyclonebox | 19 | 03-30-2010 00:04 |
nokia 2330c-2 unlock fail | m_tahir1 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-22-2010 14:37 |
Nokia 2330c RM512 unlock fail | mobista | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 02-11-2010 13:28 |
help unlock 2330c failed | snowtown | Universalbox | 6 | 10-10-2009 22:30 |
2330c -patch unlock failed | modzek | MT-BOX | 0 | 10-02-2009 17:56 |
