Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-24-2010, 18:10   #1 (permalink)
mobile_hotman's Avatar
Member: 214340
2330c_V9.55_NOT_UNLOCKED[SOLVED]
Nokia 2330c_V9.55_Not Unlocked;;
LOGS:
Imei net: 3593*************
Version: SIMLOCK SERVER
Provider: Virgin, Country: United Kingdom
Counter: 0/3, 0/10
CONFIG_DATA: 2343000000000000
PROFILE_BITS: 800000000003000B
BLOCK 1: 1.LOCKED (MCC+MNC): 23430F
PhoneType:RM-512
SwVersion: V 09.55 12-11-09 RM-512 (c) Nokia
MCU file: rm512__09.55.mcusw
Trying to find patch position ...
Sorry, no routine found or not supported model !
Old 03-24-2010, 18:20   #2 (permalink)
sijibae's Avatar
Member: 1169189
Sonork: 100.1591528
Look at here, unlock done..... using lower version
nokia 2330c-2 unlock fail
Old 03-24-2010, 18:28   #3 (permalink)
ABOUSHADY's Avatar
Member: 200717
Sonork: 100.1580056
erase flash and flash it with 8.20 write good pm and unlock it
br
ABOUSHADY
Old 03-24-2010, 18:47   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
and software already give info
Trying to find patch position ...Sorry, no routine found or not supported model !
mean is your FW version is not supported yet,
downgrade first to 8.20 firmware version afterward unlock your phone
br,
Old 03-25-2010, 18:08   #5 (permalink)
Member: 214340
br,
Yes After Downgraded Unlocked SUCCESSFULLYY Credit goes to MXKEY_TEAM,,
LOGS:
Imei net: 359xxxxxxxx
Counter: 0/3, 0/10
PhoneType:RM-512
SwVersion: V 06.75 29-04-09 RM-512 (c) Nokia
MCU file: rm512__06.75.mcusw
Trying to find patch position ...OK
ASIC ID: 0x3168 [UPP_8M ver: 6.4]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.79.0 revision: 0.7 size: 0x9D8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 00EC 2600 [Samsung ] page size: 128 K type: NOR area: 01000000-01FFFFFF - COMBO FLASH
ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000
Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.79.0 revision: 0.7 size: 0x78C8
Performing Flash Authentication ...OK
UEM ID: 008D28BA:3B8ADA60
Area [01000000-0101FFFF] erased in 0.657 s
Area [01220000-0123FFFF] erased in 0.609 s
Area [01440000-0145FFFF] erased in 0.578 s
Area [014C0000-014DFFFF] erased in 0.594 s
Area [01CE0000-01CFFFFF] erased in 0.671 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 57.125 s
Reading Simlock info ...
Imei net: 359xxxxxxxxxxxx
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
The Following User Says Thank You to mobile_hotman For This Useful Post:
Page generated in 0.21978 seconds with 10 queries
