07-01-2011, 10:49 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: aizawl
Member: 282510 Status: Offline Thanks Meter: 33 | 2600 imei ???? Code: MXKEY Serial: [FT SCR2000 0] - C0842540 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.8.14.0, NTMP ver: 2.8.14.0 Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011) ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005FA081:2984DA60 ASIC type: 2 UEM Imei: 357054020D3D31 Invalid uem checksum, UEM might be damaged ! Flash Imei: 35705400083531 MasterCode: 4537105502 Invalid imei checksum ! Phone Type: RH-59 SW Version: V 4.42 18-01-05 RH-59 (c) NMP 2600 Imei plain: ??????????????-? Product Code: 0525501 Cellular System: GSM ASIC ID: 0x1201, type: 2 Ppm Id: MB Language Pack: English,Hindi Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Counter: 13/3, 0/10 CONFIG_DATA: E65711F92D5459DD PROFILE_BITS: F566CFA32705F1E6 BLOCK1: BLOCK2: BLOCK3: BLOCK4: BLOCK5: BLOCK6: BLOCK7: BLOCK8: BLOCK9: BLOCK10: BLOCK11: BLOCK12: BLOCK13: BLOCK14: BLOCK15: BLOCK16: BLOCK17: BLOCK18: BLOCK19: BLOCK20: BLOCK21: BLOCK22: BLOCK23: BLOCK24: BLOCK25: BLOCK26: BLOCK27: BLOCK28: BLOCK29: BLOCK30: BLOCK31: BLOCK32: BLOCK33: BLOCK34: BLOCK35: BLOCK36: BLOCK37: BLOCK38: BLOCK39: BLOCK40: BLOCK41: BLOCK42: BLOCK43: BLOCK44: BLOCK45: BLOCK46: BLOCK47: BLOCK48: BLOCK49: BLOCK50: BLOCK51: BLOCK52: BLOCK53: BLOCK54: BLOCK55: BLOCK56: BLOCK57: BLOCK58: BLOCK59: BLOCK60: BLOCK61: BLOCK62: BLOCK63: BLOCK64: BLOCK65: BLOCK66: BLOCK67: BLOCK68: BLOCK69: BLOCK70: BLOCK71: BLOCK72: BLOCK73: BLOCK74: BLOCK75: BLOCK76: BLOCK77: BLOCK78: BLOCK79: BLOCK80: BLOCK81: BLOCK82: BLOCK83: BLOCK84: BLOCK85: BLOCK86: BLOCK87: BLOCK88: BLOCK89: BLOCK90: BLOCK91: BLOCK92: BLOCK93: BLOCK94: BLOCK95: BLOCK96: BLOCK97: BLOCK98: BLOCK99: BLOCK100: BLOCK101: BLOCK102: BLOCK103: BLOCK104: BLOCK105: BLOCK106: BLOCK107: BLOCK108: BLOCK109: BLOCK110: BLOCK111: BLOCK112: BLOCK113: BLOCK114: BLOCK115: BLOCK116: BLOCK117: BLOCK118: BLOCK119: BLOCK120: BLOCK121: BLOCK122: BLOCK123: BLOCK124: BLOCK125: BLOCK126: BLOCK127: BLOCK128: BLOCK129: BLOCK130: BLOCK131: BLOCK132: BLOCK133: BLOCK134: BLOCK135: BLOCK136: BLOCK137: BLOCK138: BLOCK139: BLOCK140: BLOCK141: BLOCK142: BLOCK143: BLOCK144: BLOCK145: BLOCK146: BLOCK147: BLOCK148: BLOCK149: BLOCK150: BLOCK151: BLOCK152: BLOCK153: BLOCK154: BLOCK155: BLOCK156: BLOCK157: BLOCK158: BLOCK159: BLOCK160: BLOCK161: BLOCK162: BLOCK163: BLOCK164: BLOCK165: BLOCK166: BLOCK167: BLOCK168: BLOCK169: BLOCK170: BLOCK171: BLOCK172: BLOCK173: BLOCK174: BLOCK175: BLOCK176: BLOCK177: BLOCK178: BLOCK179: BLOCK180: BLOCK181: BLOCK182: BLOCK183: BLOCK184: BLOCK185: BLOCK186: BLOCK187: BLOCK188: BLOCK189: BLOCK190: BLOCK191: BLOCK192: Code: Reading ASK DATA ... ASIC ID: 0x1201 [UPP_2M ver: 1] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005FA081:2984DA60 ASIC type: 2 UEM Imei: 357054020D3D31 Invalid uem checksum, UEM might be damaged ! [InternalErrorFault] IMEI/ESN (357054020D3D31) contains non digit char, probably UEM damaged ! (case id=0xCB01) [InternalErrorFault] IMEI/ESN (357054020D3D31) contains non digit char, probably UEM damaged ! (case id=0xCB01) [InternalErrorFault] IMEI/ESN (357054020D3D31) contains non digit char, probably UEM damaged ! (case id=0xCB01) [InternalErrorFault] IMEI/ESN (357054020D3D31) contains non digit char, probably UEM damaged ! (case id=0xCB01) |
07-01-2011, 11:06 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Faulty UEM , only solution change it >>>>>> |
The Following User Says Thank You to srinibas For This Useful Post: |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Nokia 51xx/61xx imei changer ver. 1.10?????? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 04-06-2012 16:22 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
