Old 08-23-2010, 02:21   #1 (permalink)
Crazy Poster
Member: 227204
Thanks Meter: 12
is 2600 supported for change imei?
just wondering if 2600 supported for change imei?
this is the info:
Phone Type: RH-59
SW Version: V 5.24 26-08-05 RH-59 (c) NMP 2600
Imei plain: 35620900050155-8
Product Code: 0529665
Cellular System: GSM
ASIC ID: 0x1201, type: 2
Ppm Id: AA
Language Pack:
English,Dannish,Norwegian,Swedish
Imei net: 35620900050155
Version:
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
got this error:
ASIC ID: 0x1201 [UPP_2M ver: 1]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 22D1 [AMD 29BDL32T,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
Performing Flash Authentication ...OK
UEM ID: 00D468C9:2984DA60
Trying to find patch position ...Ok, found in 10.891 s
Not supported firmware.
Error while processing command !
i also tried diff firmware high and low versions.
Old 08-23-2010, 02:25   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
2600c Yes 2600 Old Not Bro
The Following User Says Thank You to Braycel For This Useful Post:
Old 09-03-2010, 08:59   #3 (permalink)
Member: 194907
Thanks Meter: 114
ı can old versiyon imei change 2600 rh 59
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
Page generated in 0.15398 seconds with 9 queries
